Dell Inspiron 13-7352 Hinge Replacement
    1. Dell Inspiron 13-7352 Hinge Replacement, Battery: step 1, image 1 of 3 Dell Inspiron 13-7352 Hinge Replacement, Battery: step 1, image 2 of 3 Dell Inspiron 13-7352 Hinge Replacement, Battery: step 1, image 3 of 3
      • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
      • Use a Phillips screwdriver to remove the ten 7.5mm screws that securing the back panel.
      • Use the plastic opening tool to pry up and loosen the back panel.
      • Remove the back panel.
      Ask FixBot
    2. Dell Inspiron 13-7352 Hinge Replacement: step 2, image 1 of 2 Dell Inspiron 13-7352 Hinge Replacement: step 2, image 2 of 2
      • Use a Phillips screwdriver to remove the two 3 mm screws securing the battery.
      • Unclip the hard drive wire from the battery.
      Ask FixBot
    3. Dell Inspiron 13-7352 Hinge Replacement: step 3, image 1 of 1
      • Gently remove the battery from the rest of the device.
      Ask FixBot
    1. Dell Inspiron 13-7352 Hinge Replacement, Hinge: step 4, image 1 of 3 Dell Inspiron 13-7352 Hinge Replacement, Hinge: step 4, image 2 of 3 Dell Inspiron 13-7352 Hinge Replacement, Hinge: step 4, image 3 of 3
      • Remove the three 8mm screws with the Phillips #0 head connected to each of the hinges.
      • Take out the antenna cables from the routing guide on the hinge cover by pulling them from their original position
      Ask FixBot
    2. Dell Inspiron 13-7352 Hinge Replacement: step 5, image 1 of 1
      • Lay the screen flat on a smooth flat surface to release the hinges.
      Ask FixBot
    3. Dell Inspiron 13-7352 Hinge Replacement: step 6, image 1 of 3 Dell Inspiron 13-7352 Hinge Replacement: step 6, image 2 of 3 Dell Inspiron 13-7352 Hinge Replacement: step 6, image 3 of 3
      • Use the plastic opening tool around the edges of the screen to separate the screen back from the display until the backing is loose enough to pull apart with your hands.
      • The second image should be the result of removing the back of the screen.
      Ask FixBot
    4. Dell Inspiron 13-7352 Hinge Replacement: step 7, image 1 of 2 Dell Inspiron 13-7352 Hinge Replacement: step 7, image 2 of 2
      • Locate the hinge or hinges that need to be replaced and remove the two, or four, 3mm screws with the Phillips #0 head.
      • Remove the single, (or both, depending on if you are replacing one or both hinges) 6mm screw(s) from the top of the hinge with the Phillips #0 head.
      Ask FixBot
    5. Dell Inspiron 13-7352 Hinge Replacement: step 8, image 1 of 1
      • Grasp the hinge from the edge as shown and separate the hinge from the display.
      Ask FixBot
2 other people completed this guide.
Mikinna Martin
461 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 44
All Time: 7,332
