Dell Inspiron 13-7347 Display Assembly Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
Past 7 Days:
13
Past 30 Days:
76
All Time:
1,095
Comments: 1
1 comment on steps.
Completed: 0
Favorites: 0
Time Required: 40 - 55 minutes
Difficulty: Moderate
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Introduction
Go to step 1 ↓
If you have a Dell Inspiron 13-7347 laptop (Computer model Inspiron 7347) and the screen is cracked, chipped, unresponsive, or maybe your screen is flickering, you may use this guide for removal and replacement of the Display Assembly.
A "display assembly" is the complete module used to show images or information on a device, such as a phone, computer, or TV. It typically includes the display panel (like an LCD or OLED), its supporting circuitry, and sometimes a bezel or housing. You may want to replace the display assembly if it has cracks or chips, the screen is unresponsive, ghost touching, or it has display issues such as flickering, has distorted colors or even dead pixels. Below is a step by step process on how to replace the display assembly.
Before you begin this repair, make sure to power off your laptop and unplug the charging adaptor and any peripherals.
Parts
Tools
    1. Dell Inspiron 13-7347 Display Assembly Replacement, Battery: step 1, image 1 of 3 Dell Inspiron 13-7347 Display Assembly Replacement, Battery: step 1, image 2 of 3 Dell Inspiron 13-7347 Display Assembly Replacement, Battery: step 1, image 3 of 3
      • Flip the device over, so that the back is facing up.
      • Using a Phillips screwdriver, remove the 10 2.5mm x 8mm screws
      • Use the suction cup to lift off the back case.
      Ask FixBot
    2. Dell Inspiron 13-7347 Display Assembly Replacement: step 2, image 1 of 3 Dell Inspiron 13-7347 Display Assembly Replacement: step 2, image 2 of 3 Dell Inspiron 13-7347 Display Assembly Replacement: step 2, image 3 of 3
      • Remove the two 2mm x 3mm screws that secure the battery to the device.
      Ask FixBot
    3. Dell Inspiron 13-7347 Display Assembly Replacement: step 3, image 1 of 3 Dell Inspiron 13-7347 Display Assembly Replacement: step 3, image 2 of 3 Dell Inspiron 13-7347 Display Assembly Replacement: step 3, image 3 of 3
      • Unplug the cable that connects the USB / SD Reader IO Board to the motherboard.
      Ask FixBot
    4. Dell Inspiron 13-7347 Display Assembly Replacement: step 4, image 1 of 3 Dell Inspiron 13-7347 Display Assembly Replacement: step 4, image 2 of 3 Dell Inspiron 13-7347 Display Assembly Replacement: step 4, image 3 of 3
      • Lift the battery steadily from the device.
      • Tilt the battery upward while removing.
      Ask FixBot
    1. Dell Inspiron 13-7347 Display Assembly Replacement, Fan: step 5, image 1 of 2 Dell Inspiron 13-7347 Display Assembly Replacement, Fan: step 5, image 2 of 2
      • You should be able to identify the fan.
      • This is the 2mm x 2mm JIS #00 screw.
      • This is the 2mm x 3mm JIS #00 screw.
      Ask FixBot
    2. Dell Inspiron 13-7347 Display Assembly Replacement: step 6, image 1 of 2 Dell Inspiron 13-7347 Display Assembly Replacement: step 6, image 2 of 2
      • Remove the 2mm x 2mm JIS #00 screw.
      • Remove the 2mm x 3mm JIS #00 screw.
      Ask FixBot
    3. Dell Inspiron 13-7347 Display Assembly Replacement: step 7, image 1 of 2 Dell Inspiron 13-7347 Display Assembly Replacement: step 7, image 2 of 2
      • Detach the cable that connects the fan and the motherboard.
      • The cable is extremely fragile.
      Ask FixBot
    4. Dell Inspiron 13-7347 Display Assembly Replacement: step 8, image 1 of 2 Dell Inspiron 13-7347 Display Assembly Replacement: step 8, image 2 of 2
      • Detach the cord that connects the fan and the motherboard.
      Ask FixBot
    5. Dell Inspiron 13-7347 Display Assembly Replacement: step 9, image 1 of 1
      • Remove the fan.
      Ask FixBot
    1. Dell Inspiron 13-7347 Display Assembly Replacement, Hard Drive: step 10, image 1 of 2 Dell Inspiron 13-7347 Display Assembly Replacement, Hard Drive: step 10, image 2 of 2
      • Using a Phillips #0 screwdriver, loosen and remove the two 3.0 mm hard drive screws.
      • Lift the hard drive up and out of the device.
      Ask FixBot
    1. Dell Inspiron 13-7347 Display Assembly Replacement, Display Assembly: step 11, image 1 of 3 Dell Inspiron 13-7347 Display Assembly Replacement, Display Assembly: step 11, image 2 of 3 Dell Inspiron 13-7347 Display Assembly Replacement, Display Assembly: step 11, image 3 of 3
      • Using a Phillips #0 screwdriver, loosen the three 3.0 mm heat sink screws.
      • Remove the Heat Sink.
      • When reinstalling the heat sink, be sure to clean both contact surfaces with isopropyl alcohol and reapply thermal paste.
      Ask FixBot
    2. Dell Inspiron 13-7347 Display Assembly Replacement: step 12, image 1 of 1
      • Using a Phillips #0 screwdriver, remove the two 5.0 mm screws on the metal bracket.
      • Remove the metal bracket.
      Ask FixBot
    3. Dell Inspiron 13-7347 Display Assembly Replacement: step 13, image 1 of 1
      • Loosen and reposition the display cable.
      • The display cable will not be removed. Do not attempt to remove the display cable.
      Ask FixBot
    4. Dell Inspiron 13-7347 Display Assembly Replacement: step 14, image 1 of 3 Dell Inspiron 13-7347 Display Assembly Replacement: step 14, image 2 of 3 Dell Inspiron 13-7347 Display Assembly Replacement: step 14, image 3 of 3
      • Using a Phillips #0 screwdriver, remove the 5.0mm screw on the left display hinge bracket.
      • Using a Phillips #0 screwdriver, remove the two 5.0mm screws on the right display hinge bracket.
      • Lift and remove the display assembly.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 76
All Time: 1,095
