Dell Inspiron 13-7347 Battery Replacement
    1. Dell Inspiron 13-7347 Battery Replacement, Battery: step 1, image 1 of 3 Dell Inspiron 13-7347 Battery Replacement, Battery: step 1, image 2 of 3 Dell Inspiron 13-7347 Battery Replacement, Battery: step 1, image 3 of 3
      • Flip the device over, so that the back is facing up.
      • Using a Phillips screwdriver, remove the 10 2.5mm x 8mm screws
      • Use the suction cup to lift off the back case.
      Ask FixBot
    2. Dell Inspiron 13-7347 Battery Replacement: step 2, image 1 of 3 Dell Inspiron 13-7347 Battery Replacement: step 2, image 2 of 3 Dell Inspiron 13-7347 Battery Replacement: step 2, image 3 of 3
      • Remove the two 2mm x 3mm screws that secure the battery to the device.
      Ask FixBot
    3. Dell Inspiron 13-7347 Battery Replacement: step 3, image 1 of 3 Dell Inspiron 13-7347 Battery Replacement: step 3, image 2 of 3 Dell Inspiron 13-7347 Battery Replacement: step 3, image 3 of 3
      • Unplug the cable that connects the USB / SD Reader IO Board to the motherboard.
      Ask FixBot
    4. Dell Inspiron 13-7347 Battery Replacement: step 4, image 1 of 3 Dell Inspiron 13-7347 Battery Replacement: step 4, image 2 of 3 Dell Inspiron 13-7347 Battery Replacement: step 4, image 3 of 3
      • Lift the battery steadily from the device.
      • Tilt the battery upward while removing.
      Ask FixBot
lee120496
643 Reputation
4 Guides authored
UC Davis, Team S20-G8, Lore Winter 2019 Member of UC Davis, Team S20-G8, Lore Winter 2019
UCD-LORE-W19S20G8
3 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 15
Past 30 Days: 39
All Time: 1,219
