Dell Inspiron 13-5368 Touchpad Replacement
  1. Dell Inspiron 13-5368 Touchpad Replacement, Battery: step 1, image 1 of 3 Dell Inspiron 13-5368 Touchpad Replacement, Battery: step 1, image 2 of 3 Dell Inspiron 13-5368 Touchpad Replacement, Battery: step 1, image 3 of 3
    • Remove the nine 6mm Phillips #0 screws that secure the back cover of the laptop.
    Ask FixBot
  2. Dell Inspiron 13-5368 Touchpad Replacement: step 2, image 1 of 2 Dell Inspiron 13-5368 Touchpad Replacement: step 2, image 2 of 2
    • Use a spudger / pry tool to pry up and remove the back cover.
    Ask FixBot
  3. Dell Inspiron 13-5368 Touchpad Replacement: step 3, image 1 of 1
    • Remove the four 3mm Phillips #0 screws at the corners of the battery that secure it to the laptop.
    Ask FixBot
  4. Dell Inspiron 13-5368 Touchpad Replacement: step 4, image 1 of 1
    • Pull the battery cable's black tab towards the battery to disconnect it from the motherboard.
    • Pull the tab parallel to the motherboard, not straight up.
    Ask FixBot
  5. Dell Inspiron 13-5368 Touchpad Replacement: step 5, image 1 of 2 Dell Inspiron 13-5368 Touchpad Replacement: step 5, image 2 of 2
    • Lift the battery straight up out of the housing.
    Ask FixBot
  6. Dell Inspiron 13-5368 Touchpad Replacement, Touchpad: step 6, image 1 of 2 Dell Inspiron 13-5368 Touchpad Replacement, Touchpad: step 6, image 2 of 2
    • Undo the clasps that hold the ribbon cables in place. Then, remove the ribbon cables.
    Ask FixBot
  7. Dell Inspiron 13-5368 Touchpad Replacement: step 7, image 1 of 1
    • Remove the 1.5mm Phillips #0 screws that hold the touchpad to the laptop case.
    Ask FixBot
  8. Dell Inspiron 13-5368 Touchpad Replacement: step 8, image 1 of 2 Dell Inspiron 13-5368 Touchpad Replacement: step 8, image 2 of 2
    • Push up on the touchpad to release it from the housing. Then you can remove the touchpad.
    Ask FixBot
Matt Sugrim
1,078 Reputation
6 Guides authored
USF Tampa, Team S14-G6, Boczar Fall 2017 Member of USF Tampa, Team S14-G6, Boczar Fall 2017
USFT-BOCZAR-F17S14G6
4 Members
13 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 27
All Time: 4,311
