Dell Inspiron 13-5368 Screen Display Replacement
    1. Dell Inspiron 13-5368 Screen Display Replacement, Battery: step 1, image 1 of 3 Dell Inspiron 13-5368 Screen Display Replacement, Battery: step 1, image 2 of 3 Dell Inspiron 13-5368 Screen Display Replacement, Battery: step 1, image 3 of 3
      • Remove the nine 6mm Phillips #0 screws that secure the back cover of the laptop.
      Ask FixBot
    2. Dell Inspiron 13-5368 Screen Display Replacement: step 2, image 1 of 2 Dell Inspiron 13-5368 Screen Display Replacement: step 2, image 2 of 2
      • Use a spudger / pry tool to pry up and remove the back cover.
      Ask FixBot
    3. Dell Inspiron 13-5368 Screen Display Replacement: step 3, image 1 of 1
      • Remove the four 3mm Phillips #0 screws at the corners of the battery that secure it to the laptop.
      Ask FixBot
    4. Dell Inspiron 13-5368 Screen Display Replacement: step 4, image 1 of 1
      • Pull the battery cable's black tab towards the battery to disconnect it from the motherboard.
      • Pull the tab parallel to the motherboard, not straight up.
      Ask FixBot
    5. Dell Inspiron 13-5368 Screen Display Replacement: step 5, image 1 of 2 Dell Inspiron 13-5368 Screen Display Replacement: step 5, image 2 of 2
      • Lift the battery straight up out of the housing.
      Ask FixBot
    1. Dell Inspiron 13-5368 Screen Display Replacement, Screen Display: step 6, image 1 of 3 Dell Inspiron 13-5368 Screen Display Replacement, Screen Display: step 6, image 2 of 3 Dell Inspiron 13-5368 Screen Display Replacement, Screen Display: step 6, image 3 of 3
      • Unscrew the 2mm screw that holds the WLAN card. Then carefully remove the WLAN card from the motherboard.
      Ask FixBot
    2. Dell Inspiron 13-5368 Screen Display Replacement: step 7, image 1 of 1
      • Detach the black and white antenna cables from the WLAN card.
      Ask FixBot
    3. Dell Inspiron 13-5368 Screen Display Replacement: step 8, image 1 of 1
      • Unplug the two display cables.
      Ask FixBot
    4. Dell Inspiron 13-5368 Screen Display Replacement: step 9, image 1 of 1
      • Unscrew the screws that are securing the laptop's hinges.
      Ask FixBot
    5. Dell Inspiron 13-5368 Screen Display Replacement: step 10, image 1 of 1
      • Detach the display from the base.
      Ask FixBot
3 other people completed this guide.
Matt Sugrim
1,078 Reputation
6 Guides authored
USF Tampa, Team S14-G6, Boczar Fall 2017 Member of USF Tampa, Team S14-G6, Boczar Fall 2017
USFT-BOCZAR-F17S14G6
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 22
Past 30 Days: 105
All Time: 2,958
