Dell Inspiron 13-5368 Fan Replacement
  1. Dell Inspiron 13-5368 Fan Replacement, Battery: step 1, image 1 of 3 Dell Inspiron 13-5368 Fan Replacement, Battery: step 1, image 2 of 3 Dell Inspiron 13-5368 Fan Replacement, Battery: step 1, image 3 of 3
    • Remove the nine 6mm Phillips #0 screws that secure the back cover of the laptop.
    Ask FixBot
  2. Dell Inspiron 13-5368 Fan Replacement: step 2, image 1 of 2 Dell Inspiron 13-5368 Fan Replacement: step 2, image 2 of 2
    • Use a spudger / pry tool to pry up and remove the back cover.
    Ask FixBot
  3. Dell Inspiron 13-5368 Fan Replacement: step 3, image 1 of 1
    • Remove the four 3mm Phillips #0 screws at the corners of the battery that secure it to the laptop.
    Ask FixBot
  4. Dell Inspiron 13-5368 Fan Replacement: step 4, image 1 of 1
    • Pull the battery cable's black tab towards the battery to disconnect it from the motherboard.
    • Pull the tab parallel to the motherboard, not straight up.
    Ask FixBot
  5. Dell Inspiron 13-5368 Fan Replacement: step 5, image 1 of 2 Dell Inspiron 13-5368 Fan Replacement: step 5, image 2 of 2
    • Lift the battery straight up out of the housing.
    Ask FixBot
  6. Dell Inspiron 13-5368 Fan Replacement, Fan: step 6, image 1 of 1
    • Remove both of the 2mm X 3mm screws that are securing the fan.
    Ask FixBot
  7. Dell Inspiron 13-5368 Fan Replacement: step 7, image 1 of 2 Dell Inspiron 13-5368 Fan Replacement: step 7, image 2 of 2
    • Unplug the fan from the motherboard by pulling the cable towards the fan. Then remove the fan.
    • Just like the battery, remove the fan by lifting it straight up out of the housing.
    Ask FixBot
Matt Sugrim
1,078 Reputation
6 Guides authored
USF Tampa, Team S14-G6, Boczar Fall 2017 Member of USF Tampa, Team S14-G6, Boczar Fall 2017
USFT-BOCZAR-F17S14G6
4 Members
13 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 33
All Time: 1,801
