Dell Inspiron 13 7378 RAM Replacement
    1. Dell Inspiron 13 7378 RAM Replacement, Back Cover: step 1, image 1 of 1
      • Set the laptop with its underside facing up for improved accessibility.
      Ask FixBot
    2. Dell Inspiron 13 7378 RAM Replacement: step 2, image 1 of 2 Dell Inspiron 13 7378 RAM Replacement: step 2, image 2 of 2
      • Using a Phillips #00 screwdriver, extract the nine 3 mm screws located on the back of the laptop.
      Ask FixBot
    3. Dell Inspiron 13 7378 RAM Replacement: step 3, image 1 of 3 Dell Inspiron 13 7378 RAM Replacement: step 3, image 2 of 3 Dell Inspiron 13 7378 RAM Replacement: step 3, image 3 of 3
      • Carefully pry open the back of the back of the laptop using opening picks.
      • Carefully raise and detach the back cover from the laptop.
      • Exercise caution to prevent damaging or cracking the device's back cover.
      Ask FixBot
    1. Dell Inspiron 13 7378 RAM Replacement, RAM: step 4, image 1 of 3 Dell Inspiron 13 7378 RAM Replacement, RAM: step 4, image 2 of 3 Dell Inspiron 13 7378 RAM Replacement, RAM: step 4, image 3 of 3
      • To remove a RAM stick, gently pull apart the metal tabs on either side of the stick.
      • Carefully grasp the stick on its side and pull it out.
      • The plastic sheet covering the RAM compartment depicts the process.
      Ask FixBot
    2. Dell Inspiron 13 7378 RAM Replacement: step 5, image 1 of 1
      • When inserting the new stick, make sure that the gap on in the stick aligns with the gap in the slot.
      Ask FixBot
Emma Simon
165 Reputation
1 Guide authored
Gateway, Team 1-3, Saknee Spring 2022 Member of Gateway, Team 1-3, Saknee Spring 2022
GCC-SAKNEE-S22S1G3
5 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 18
Past 30 Days: 75
All Time: 1,034
