Dell Inspiron 13 7378 Fan Replacement
    1. Dell Inspiron 13 7378 Fan Replacement, Back Cover: step 1, image 1 of 1
      • Set the laptop with its underside facing up for improved accessibility.
      Ask FixBot
    2. Dell Inspiron 13 7378 Fan Replacement: step 2, image 1 of 2 Dell Inspiron 13 7378 Fan Replacement: step 2, image 2 of 2
      • Using a Phillips #00 screwdriver, extract the nine 3 mm screws located on the back of the laptop.
      Ask FixBot
    3. Dell Inspiron 13 7378 Fan Replacement: step 3, image 1 of 3 Dell Inspiron 13 7378 Fan Replacement: step 3, image 2 of 3 Dell Inspiron 13 7378 Fan Replacement: step 3, image 3 of 3
      • Carefully pry open the back of the back of the laptop using opening picks.
      • Carefully raise and detach the back cover from the laptop.
      • Exercise caution to prevent damaging or cracking the device's back cover.
      Ask FixBot
    1. Dell Inspiron 13 7378 Fan Replacement, Fan: step 4, image 1 of 1
      • Remove the two 3 mm screws holding the fan in place using a Phillips screwdriver.
      Ask FixBot
    2. Dell Inspiron 13 7378 Fan Replacement: step 5, image 1 of 3 Dell Inspiron 13 7378 Fan Replacement: step 5, image 2 of 3 Dell Inspiron 13 7378 Fan Replacement: step 5, image 3 of 3
      • Disconnect the fan's connector from the motherboard.
      • Remove the fan from the laptop.
      Ask FixBot
Replace the back cover to complete the process.
2 other people completed this guide.
Javier Perez
277 Reputation
2 Guides authored
Gateway, Team 1-3, Saknee Spring 2022 Member of Gateway, Team 1-3, Saknee Spring 2022
GCC-SAKNEE-S22S1G3
5 Members
71 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 9
Past 30 Days: 30
All Time: 691
