Up to 20% off select tools
Dell Inspiron 13 7368 Memory Modules Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
13
Past 30 Days:
51
All Time:
944
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 - 40 minutes
Difficulty: Easy
Community-Contributed Guide
Tools
  • Phillips #0 Screwdriver
    5
  • Spudger
    4.9
Introduction
Go to step 1 ↓
In this guide, we will show you how to remove and replace the Memory Modules.
    1. Dell Inspiron 13 7368 Memory Modules Replacement, Disconnecting the Battery Cable: step 1, image 1 of 1
      Ask FixBot
    2. Dell Inspiron 13 7368 Memory Modules Replacement, Remove the Screws: step 2, image 1 of 1
      • Remove the screws that secure the battery to the palm-rest assembly.
      Ask FixBot
    3. Dell Inspiron 13 7368 Memory Modules Replacement, Lifting the Battery: step 3, image 1 of 1
      • Lift the battery off the palm-rest assembly.
      Ask FixBot
      • Press and hold the power button for five seconds to ground the system board.
      Ask FixBot
    4. Dell Inspiron 13 7368 Memory Modules Replacement, Align the Screw Holes: step 5, image 1 of 1
      • Align the screw holes on the battery with the screw holes on the palm-rest assembly.
      Ask FixBot
    5. Dell Inspiron 13 7368 Memory Modules Replacement, Replace the Screws: step 6, image 1 of 1
      • Replace the screws that secure the battery to the palm-rest assembly.
      Ask FixBot
    6. Dell Inspiron 13 7368 Memory Modules Replacement, Connecting the Battery Cable: step 7, image 1 of 1
      • Connect the battery cable to the system board.
      Ask FixBot
    1. Dell Inspiron 13 7368 Memory Modules Replacement, Lifting the Mylar: step 8, image 1 of 1
      Ask FixBot
    2. Dell Inspiron 13 7368 Memory Modules Replacement, Popping up the Memory Module: step 9, image 1 of 1
      • Use your fingertips to carefully spread apart the securing-clips on each end of the memory-module slot until the memory module pops up.
      Ask FixBot
    3. Dell Inspiron 13 7368 Memory Modules Replacement, Removing the Memory Module: step 10, image 1 of 2 Dell Inspiron 13 7368 Memory Modules Replacement, Removing the Memory Module: step 10, image 2 of 2
      • Remove the memory module from the memory-module slot.
      Ask FixBot
    4. Dell Inspiron 13 7368 Memory Modules Replacement, Lifting the Mylar: step 11, image 1 of 1
      • Lift the Mylar to access the memory-module slot.
      Ask FixBot
    5. Dell Inspiron 13 7368 Memory Modules Replacement, Align the Notch: step 12, image 1 of 1
      • Align the notch on the memory module with the tab on the memory-module slot.
      Ask FixBot
    6. Dell Inspiron 13 7368 Memory Modules Replacement, Sliding the Memory Module: step 13, image 1 of 1
      • Slide the memory module firmly into the slot at an angle and press the memory module down until it clicks into place.
      • NOTE: If you do not hear the click, remove the memory module and reinstall it.
      Ask FixBot
Finish Line
Author
with
Terrence15
80,173 Reputation
441 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
45 Members
12,349 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 13
Past 30 Days: 51
All Time: 944
