Dell Inspiron 13 1370 Memory Modules Replacement
    1. Dell Inspiron 13 1370 Memory Modules Replacement, Remove the Screw: step 1, image 1 of 1
      • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the procedures in Before You Begin.
      • Remove the screw that secures the memory module cover to the computer base.
      Ask FixBot
    2. Dell Inspiron 13 1370 Memory Modules Replacement, Lifting the Memory Module Cover: step 2, image 1 of 1
      • Use a plastic scribe to lift the memory module cover up at an angle and ease the tabs out of the computer base.
      Ask FixBot
    3. Dell Inspiron 13 1370 Memory Modules Replacement, Popping up the Memory Module: step 3, image 1 of 1
      • CAUTION: To prevent damage to the memory module connector, do not use tools to spread the memory module securing clips.
      • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the module pops up.
      Ask FixBot
    4. Dell Inspiron 13 1370 Memory Modules Replacement, Removing the Memory Module: step 4, image 1 of 2 Dell Inspiron 13 1370 Memory Modules Replacement, Removing the Memory Module: step 4, image 2 of 2
      • Remove the memory module from the memory module connector.
      Ask FixBot
    5. Dell Inspiron 13 1370 Memory Modules Replacement, Align the Notch: step 5, image 1 of 1
      • Align the notch in the NEW memory module with the tab in the memory module connector.
      Ask FixBot
    6. Dell Inspiron 13 1370 Memory Modules Replacement, Sliding the Memory Module: step 6, image 1 of 1
      • Slide the memory module firmly into the slot at a 45-degree angle, and press the memory module down until it clicks into place. If you do not hear the click, remove the memory module and reinstall it.
      • NOTE: If the memory module is not installed properly, the computer may not boot.
      Ask FixBot
    7. Dell Inspiron 13 1370 Memory Modules Replacement, Align the Tabs: step 7, image 1 of 1
      • Align the tabs on the memory module cover with the slots on the computer base and snap the cover into place.
      Ask FixBot
    8. Dell Inspiron 13 1370 Memory Modules Replacement, Replace the Screw: step 8, image 1 of 1
      • Replace the screw that secures the memory module cover to the computer base.
      Ask FixBot
Terrence15
80,143 Reputation
441 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
45 Members
12,349 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 71
All Time: 458
