Dell Inspiron 11z-1121 RAM Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
20
Past 30 Days:
88
All Time:
858
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
RAM is used whenever any sort of application is open on your computer. The more applications that are open, the more RAM that is being used. If you find that your computer is not capable of running apps at decent speed then replacing the RAM can help fix that issue.
Tools
    1. Dell Inspiron 11z-1121 RAM Replacement, Battery: step 1, image 1 of 2 Dell Inspiron 11z-1121 RAM Replacement, Battery: step 1, image 2 of 2
      • Slide the latches outward to release the battery.
      • Pull the battery outward to remove.
      • The latches should lock in place, allowing for easy removal.
      • The battery must be removed for safety reasons when replacing other components of the laptop.
      Ask FixBot
    1. Dell Inspiron 11z-1121 RAM Replacement, RAM: step 2, image 1 of 2 Dell Inspiron 11z-1121 RAM Replacement, RAM: step 2, image 2 of 2
      • With a Phillips #1, loosen the 1 mm screw attaching the access door to the laptop body
      • Using your fingers, remove the access door to expose the memory card
      Ask FixBot
    2. Dell Inspiron 11z-1121 RAM Replacement: step 3, image 1 of 2 Dell Inspiron 11z-1121 RAM Replacement: step 3, image 2 of 2
      • To access the memory card, push out the lashes on the left and the right of the memory card.
      • To remove the memory card, use your fingers to pull it out with the lashes still stretched out.
      Ask FixBot
Jerativat Satayarekha
123 Reputation
1 Guide authored
USF Tampa, Team 1-5, Nance Fall 2016 Member of USF Tampa, Team 1-5, Nance Fall 2016
USFT-NANCE-F16S1G5
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 20
Past 30 Days: 88
All Time: 858
