Dell Inspiron 11z-1121 Display Assembly Replacement
    1. Dell Inspiron 11z-1121 Display Assembly Replacement, Disconnecting the Mini-Card Cables: step 1, image 1 of 1
      • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in Before You Begin.
      • Disconnect the Mini-Card antenna cables from the Mini-Card(s).
      Ask FixBot
    2. Dell Inspiron 11z-1121 Display Assembly Replacement, Dislodge the Cables: step 2, image 1 of 1
      • Make note of the cable routing and carefully dislodge the Mini-Card antenna cables from the routing guides.
      Ask FixBot
    3. Dell Inspiron 11z-1121 Display Assembly Replacement, Disconnecting the Display Cable: step 3, image 1 of 1
      • Disconnect the display cable from the system board connector.
      Ask FixBot
    4. Dell Inspiron 11z-1121 Display Assembly Replacement, Remove the Screws: step 4, image 1 of 1
      • Remove the two screws (one on each side) that secure the display assembly to the computer base.
      Ask FixBot
    5. Dell Inspiron 11z-1121 Display Assembly Replacement, Lifting and Removing the Display Assembly: step 5, image 1 of 1
      • Lift and remove the display assembly off the computer base.
      Ask FixBot
    6. Dell Inspiron 11z-1121 Display Assembly Replacement, Replace the Screws: step 6, image 1 of 1
      • Place the NEW display assembly in position and replace the two screws (one on each side) that secure the display assembly to the computer base.
      Ask FixBot
    7. Dell Inspiron 11z-1121 Display Assembly Replacement, Connecting the Display Cable: step 7, image 1 of 1
      • Connect the display cable to the system board connector.
      Ask FixBot
    8. Dell Inspiron 11z-1121 Display Assembly Replacement, Routing the Cables: step 8, image 1 of 1
      • Route the Mini-Card antenna cables through the routing guides on the computer base.
      Ask FixBot
    9. Dell Inspiron 11z-1121 Display Assembly Replacement, Connecting the Cables: step 9, image 1 of 1
      • Connect the Mini-Card antenna cables to the Mini-Card(s).
      Ask FixBot
Terrence15
80,125 Reputation
441 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
45 Members
12,153 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 17
All Time: 477
