Dell Inspiron 11z 1110 Display Assembly Replacement
    1. Dell Inspiron 11z 1110 Display Assembly Replacement, Dislodge the Mini-Card Antenna Cables: step 1, image 1 of 1
      • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the procedures in Before You Begin.
      • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
      • Make note of the cable routing and carefully dislodge the Mini-Card antenna cables from the routing guides.
      Ask FixBot
    2. Dell Inspiron 11z 1110 Display Assembly Replacement, Disconnecting the Display Cable: step 2, image 1 of 1
      • Disconnect the display cable and the camera cable from the system board connectors.
      Ask FixBot
    3. Dell Inspiron 11z 1110 Display Assembly Replacement, Remove the Screws: step 3, image 1 of 1
      • Remove the two screws (one on each side) that secure the display assembly to the computer base.
      Ask FixBot
    4. Dell Inspiron 11z 1110 Display Assembly Replacement, Lifting the Display Assembly: step 4, image 1 of 1
      • Lift the display assembly off the computer.
      Ask FixBot
    5. Dell Inspiron 11z 1110 Display Assembly Replacement, Placing the Display Assembly: step 5, image 1 of 1
      • Place the NEW display assembly in position and replace the two screws (one on each side) that secure the display assembly to the computer base.
      Ask FixBot
    6. Dell Inspiron 11z 1110 Display Assembly Replacement, Routing the Mini-Card Antenna Cables: step 6, image 1 of 1
      • Route the Mini-Card antenna cables through the routing guides.
      Ask FixBot
Terrence15
80,125 Reputation
441 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
45 Members
12,206 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 34
All Time: 616
