Dell Inspiron 1100 Keyboard Replacement
    1. Dell Inspiron 1100 Keyboard Replacement, Keyboard: step 1, image 1 of 3 Dell Inspiron 1100 Keyboard Replacement, Keyboard: step 1, image 2 of 3 Dell Inspiron 1100 Keyboard Replacement, Keyboard: step 1, image 3 of 3
      • Remove the plastic face plate from the laptop using the iFixit Plastic Opening Tool.
      • Start by inserting the iFixit Plastic Opening Tool into the groove on the right side of the face plate.
      • This step does require some force. Be careful to not bend or break the plastic face plate.
      Ask FixBot
    2. Dell Inspiron 1100 Keyboard Replacement: step 2, image 1 of 2 Dell Inspiron 1100 Keyboard Replacement: step 2, image 2 of 2
      • Remove the four 3mm Phillips #0 screws securing the keyboard.
      Ask FixBot
    3. Dell Inspiron 1100 Keyboard Replacement: step 3, image 1 of 1
      • Lift up the keyboard to expose the ribbon header on the motherboard.
      • Be careful as the keyboard can only move a little ways from the surface of the laptop and is easily damaged.
      Ask FixBot
    4. Dell Inspiron 1100 Keyboard Replacement: step 4, image 1 of 2 Dell Inspiron 1100 Keyboard Replacement: step 4, image 2 of 2
      • Grip the ribbon on its hard plastic connector, and pull the ribbon and its connector out of the motherboard header.
      • Do not pull on the ribbon itself, as this may cause internal damage to the connector.
      Ask FixBot
2 other people completed this guide.
Alexander Pacheco
628 Reputation
5 Guides authored
UMass Dartmouth, Team 3-3, Isaacson Fall 2016 Member of UMass Dartmouth, Team 3-3, Isaacson Fall 2016
UMASSD-ISAACSON-F16S3G3
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 23
Past 30 Days: 106
All Time: 889
