Dell Inspiron 11-3168 Memory modules Replacement
    1. Dell Inspiron 11-3168 Memory modules Replacement, Battery: step 1, image 1 of 2 Dell Inspiron 11-3168 Memory modules Replacement, Battery: step 1, image 2 of 2
      • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
      • Using a Phillips #00 screwdriver, remove all nine 7.5mm screws from the bottom case of the laptop.
      Ask FixBot
    2. Dell Inspiron 11-3168 Memory modules Replacement: step 2, image 1 of 3 Dell Inspiron 11-3168 Memory modules Replacement: step 2, image 2 of 3 Dell Inspiron 11-3168 Memory modules Replacement: step 2, image 3 of 3
      • Remove the bottom case of the laptop by gently prying along the seam with a plastic opening tool.
      Ask FixBot
    3. Dell Inspiron 11-3168 Memory modules Replacement: step 3, image 1 of 2 Dell Inspiron 11-3168 Memory modules Replacement: step 3, image 2 of 2
      • Remove the one 7.5mm screw that is holding the battery in place.
      Ask FixBot
    4. Dell Inspiron 11-3168 Memory modules Replacement: step 4, image 1 of 2 Dell Inspiron 11-3168 Memory modules Replacement: step 4, image 2 of 2
      • Disconnect the battery cable from its motherboard socket by gently pulling it towards the battery.
      • Pull parallel to the battery, not straight up.
      Ask FixBot
    5. Dell Inspiron 11-3168 Memory modules Replacement: step 5, image 1 of 3 Dell Inspiron 11-3168 Memory modules Replacement: step 5, image 2 of 3 Dell Inspiron 11-3168 Memory modules Replacement: step 5, image 3 of 3
      • Remove the battery.
      Ask FixBot
    1. Dell Inspiron 11-3168 Memory modules Replacement, Memory modules: step 6, image 1 of 3 Dell Inspiron 11-3168 Memory modules Replacement, Memory modules: step 6, image 2 of 3 Dell Inspiron 11-3168 Memory modules Replacement, Memory modules: step 6, image 3 of 3
      • Press down on the two latches on either side of the memory module.
      • Lift and remove the memory module.
      Ask FixBot
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 20
Past 30 Days: 76
All Time: 1,269
