Dell Inspiron 11-3164 Keyboard Replacement
    1. Dell Inspiron 11-3164 Keyboard Replacement, Keyboard: step 1, image 1 of 2 Dell Inspiron 11-3164 Keyboard Replacement, Keyboard: step 1, image 2 of 2
      • Place laptop upside down to observe the first set of screws on the bottom cover. With the J1 Phillips head screwdriver bit, unscrew eight (8) size 60 mm screws.
      • With a metal spudger, remove the plastic cover to unveil the final screw.
      • With the J1 Phillips head bit, remove remaining 60 mm screw.
      Ask FixBot
    2. Dell Inspiron 11-3164 Keyboard Replacement: step 2, image 1 of 2 Dell Inspiron 11-3164 Keyboard Replacement: step 2, image 2 of 2
      Tool used on this step:
      Buy
      • With a metal spudger, pry apart the bottom cover working around the edges.
      • While separating the halves of the bottom cover, carefully move the spudger up and down to avoid damaging the USB/Audio circuit board cable inside.
      • With tweezers, disconnect the USB/Audio circuit board cable.
      • Place the bottom cover off to the side.
      Ask FixBot
    3. Dell Inspiron 11-3164 Keyboard Replacement: step 3, image 1 of 1
      • With the J1 screwdriver bit, unscrew three (3) size 40 mm battery screws.
      Ask FixBot
    4. Dell Inspiron 11-3164 Keyboard Replacement: step 4, image 1 of 1
      • With tweezers, disconnect the battery cable.
      • Remove the battery pack.
      Ask FixBot
    5. Dell Inspiron 11-3164 Keyboard Replacement: step 5, image 1 of 3 Dell Inspiron 11-3164 Keyboard Replacement: step 5, image 2 of 3 Dell Inspiron 11-3164 Keyboard Replacement: step 5, image 3 of 3
      • Remove the M2 x 3mm bracket screw.
      • Remove the metal bracket.
      • With tweezers, detach the white and black antenna cables connected to the Wireless WLAN Card.
      • Remove the Wireless WLAN Card.
      Ask FixBot
    6. Dell Inspiron 11-3164 Keyboard Replacement: step 6, image 1 of 1
      • With tweezers, unplug the CMOS battery.
      • With tweezers, detach the CMOS battery.
      Ask FixBot
    7. Dell Inspiron 11-3164 Keyboard Replacement: step 7, image 1 of 2 Dell Inspiron 11-3164 Keyboard Replacement: step 7, image 2 of 2
      • With tweezers, unplug the DC Jack cable.
      • With the Philips #0 Screwdriver, loosen the M2 x 3mm screw.
      • With tweezers, detach the DC Jack.
      Ask FixBot
    8. Dell Inspiron 11-3164 Keyboard Replacement: step 8, image 1 of 2 Dell Inspiron 11-3164 Keyboard Replacement: step 8, image 2 of 2
      • With tweezers, disconnect the speaker cable.
      • With tweezers, detach the speaker.
      Ask FixBot
    9. Dell Inspiron 11-3164 Keyboard Replacement: step 9, image 1 of 2 Dell Inspiron 11-3164 Keyboard Replacement: step 9, image 2 of 2
      • With the Philips #0 Screwdriver, unbolt the M2 x 3mm screw.
      • With tweezers, disconnect the display cable.
      Ask FixBot
    10. Dell Inspiron 11-3164 Keyboard Replacement: step 10, image 1 of 3 Dell Inspiron 11-3164 Keyboard Replacement: step 10, image 2 of 3 Dell Inspiron 11-3164 Keyboard Replacement: step 10, image 3 of 3
      • With the Philips #0 Screwdriver, unfasten the 2 - M2.5 x 5mm left and right hinge screws.
      • With the Philips #0 Screwdriver, unhinge the 2 - M2.5 x 5mm display cable bracket screw.
      • With tweezers, remove the LCD screen.
      Ask FixBot
    11. Dell Inspiron 11-3164 Keyboard Replacement: step 11, image 1 of 1
      • With the Philips #0 Screwdriver, loosen the 4 screws supporting the copper plate.
      • With tweezers, remove the copper plate.
      Ask FixBot
    12. Dell Inspiron 11-3164 Keyboard Replacement: step 12, image 1 of 2 Dell Inspiron 11-3164 Keyboard Replacement: step 12, image 2 of 2
      • With tweezers, disconnect the keyboard cable.
      • With tweezers, disconnect the touchpad cable.
      • With the Philips #00 Screwdriver, loosen the four (4) M2 x 2mm screws.
      • Gently remove the mouse touchpad. The fixer is left with the palm-rest and keyboard assembly.
      Ask FixBot
Michael Kendziora
781 Reputation
5 Guides authored
USF Tampa, Team S6-G4, Eyestone Spring 2018 Member of USF Tampa, Team S6-G4, Eyestone Spring 2018
USFT-EYESTONE-S18S6G4
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 17
Past 30 Days: 70
All Time: 772
