Dell Inspiron 11-3164 Battery Replacement
    1. Dell Inspiron 11-3164 Battery Replacement, Battery: step 1, image 1 of 2 Dell Inspiron 11-3164 Battery Replacement, Battery: step 1, image 2 of 2
      • Start by placing the laptop upside down to expose the first set of screws on the bottom of the laptop. Use your J1 Phillips head screwdriver bit to unscrew the 8 size 6 mm screws.
      • Remove the plastic cover to unveil the final screw holding the front and back frame together.
      • Remove this last screw of size 6mm with the J1 phillips head bit found in the approved iFixit toolkit.
      Ask FixBot
    2. Dell Inspiron 11-3164 Battery Replacement: step 2, image 1 of 2 Dell Inspiron 11-3164 Battery Replacement: step 2, image 2 of 2
      • Using your metal pry tool, slowly pry the two halves apart by gently moving your tool around the laptop . Once all the way around the top and bottom half will separate.
      • When pulling the laptops apart be careful to hold them together at first due to the sensitive ribbon cable inside.
      • Use your metal pry tool again to push the ribbon holding clip up and remove the ribbon cable.
      Ask FixBot
    3. Dell Inspiron 11-3164 Battery Replacement: step 3, image 1 of 1
      • Use the J1 screw driver bit from earlier and unscrew the three size 4mm battery screws.
      Ask FixBot
    4. Dell Inspiron 11-3164 Battery Replacement: step 4, image 1 of 1
      • While using one hand to hold the laptop grab the power wire with the other hand and pull it out of it's port.
      • Carefully remove the battery pack from the case.
      Ask FixBot
Michael Kendziora
781 Reputation
5 Guides authored
USF Tampa, Team S6-G4, Eyestone Spring 2018 Member of USF Tampa, Team S6-G4, Eyestone Spring 2018
USFT-EYESTONE-S18S6G4
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 38
All Time: 655
