Introduction
Go to step 1 ↓This guide will show you how to remove your screen so you can replace it.
Tools
Spudger4.9
After taking off the back panel, you will see the battery located at the bottom of the computer system. It's black and is clearly labeled "dell battery".
Unscrew the brackets in the top right and top left of the laptop. Unscrew the two 1mm screw from both of the brackets on both sides with #0 phillips head.
