Dell Inspiron 11-3152 Battery Replacement
    1. Dell Inspiron 11-3152 Battery Replacement, Back Panel: step 1, image 1 of 2 Dell Inspiron 11-3152 Battery Replacement, Back Panel: step 1, image 2 of 2
      • Flip the computer over.
      Ask FixBot
    2. Dell Inspiron 11-3152 Battery Replacement: step 2, image 1 of 2 Dell Inspiron 11-3152 Battery Replacement: step 2, image 2 of 2
      • Remove all nine 5mm Phillips head screws from the back cover using #0 Phillips head.
      Ask FixBot
    3. Dell Inspiron 11-3152 Battery Replacement: step 3, image 1 of 1
      • Gently use a spudger to pull the cover away from the rest of the laptop. The cover will come off after you use the tool on two or three sides.
      Ask FixBot
    1. Dell Inspiron 11-3152 Battery Replacement, Battery: step 4, image 1 of 1
      • Make sure that the power is off.
      • After taking off the back panel, you will see the battery located at the bottom of the computer system. It's black and is clearly labeled "dell battery".
      Ask FixBot
    2. Dell Inspiron 11-3152 Battery Replacement: step 5, image 1 of 2 Dell Inspiron 11-3152 Battery Replacement: step 5, image 2 of 2
      • Locate the battery at the bottom of the computer and remove the four 3mm screws with a Phillips #0 head that hold the battery down.
      Ask FixBot
    3. Dell Inspiron 11-3152 Battery Replacement: step 6, image 1 of 1
      • Remove the Solid State Drive wire from the battery clip by detaching the wire.
      • This can be done by gently pulling the connector away from the battery clip.
      Ask FixBot
    4. Dell Inspiron 11-3152 Battery Replacement: step 7, image 1 of 1
      • Remove the battery from the computer system by gently lifting it from the side.
      Ask FixBot
Matthew Duncan
481 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 23
All Time: 1,056
