Dell Inspiron 15-7569 Solid State Drive Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
16
Past 30 Days:
64
All Time:
797
Comments: 1
1 guide comment.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 4 minutes
Difficulty: Moderate
Needs More Images
A few more images would make this guide's procedures crystal clear.
Introduction
Go to step 1 ↓
It is advised to proceed with caution when carrying out this procedure. Damage to the sensitive electronic components may occur.
Tools
    1. Dell Inspiron  15-7569 Solid State Drive Replacement, Back Cover: step 1, image 1 of 3 Dell Inspiron  15-7569 Solid State Drive Replacement, Back Cover: step 1, image 2 of 3 Dell Inspiron  15-7569 Solid State Drive Replacement, Back Cover: step 1, image 3 of 3
      • Remove the (10) P58F black screws on the back cover using the Phillips #0 screwdriver.
      • After removing the screws, remove the back cover using a plastic or metal spudger.
      Ask FixBot
    1. Dell Inspiron  15-7569 Solid State Drive Replacement, Solid State Drive: step 2, image 1 of 1
      • Unscrew the 3.7mm screw that attaches the solid state drive with the Phillips #0 screwdriver.
      Ask FixBot
    2. Dell Inspiron  15-7569 Solid State Drive Replacement: step 3, image 1 of 1
      • Gently remove the solid state drive.
      Ask FixBot
2 other people completed this guide.
Lucas Fisher
211 Reputation
2 Guides authored
IUPUI, Team S2-G1, Harley Spring 2019 Member of IUPUI, Team S2-G1, Harley Spring 2019
IUPUI-HARLEY-S19S2G1
3 Members
24 Guides authored
1 Guide Comment
what hard drive can you replace it with?
Sean McPhillips - Reply Share
Past 24 Hours: 1
Past 7 Days: 16
Past 30 Days: 64
All Time: 797
