Dell Inpiron 3542 Motherboard Replacement
    1. Dell Inpiron 3542 Motherboard  Replacement, Motherboard: step 1, image 1 of 2 Dell Inpiron 3542 Motherboard  Replacement, Motherboard: step 1, image 2 of 2
      • Slide the latches on both sides of the laptop outward to unlock the battery.
      • Remove the battery from the computer.
      • Replacing a motherboard can lead to data loss. Make sure to backup any important data on the laptop before replacing the motherboard.
      Ask FixBot
    2. Dell Inpiron 3542 Motherboard  Replacement: step 2, image 1 of 2 Dell Inpiron 3542 Motherboard  Replacement: step 2, image 2 of 2
      • Remove the screw. (1 x M2 x 3mm)
      • Slide down the access door and remove it.
      Ask FixBot
    3. Dell Inpiron 3542 Motherboard  Replacement: step 3, image 1 of 3 Dell Inpiron 3542 Motherboard  Replacement: step 3, image 2 of 3 Dell Inpiron 3542 Motherboard  Replacement: step 3, image 3 of 3
      • Move the hard drive to the open area and remove it.
      Ask FixBot
    4. Dell Inpiron 3542 Motherboard  Replacement: step 4, image 1 of 3 Dell Inpiron 3542 Motherboard  Replacement: step 4, image 2 of 3 Dell Inpiron 3542 Motherboard  Replacement: step 4, image 3 of 3
      • Unplug the black and white antenna cables from the wireless card.
      • Remove the wireless card from the laptop.
      Ask FixBot
    5. Dell Inpiron 3542 Motherboard  Replacement: step 5, image 1 of 2 Dell Inpiron 3542 Motherboard  Replacement: step 5, image 2 of 2
      • Remove all screws from the bottom of the laptop. (10 x M2.5 x 5mm)
      • Turn over the laptop and open it.
      Ask FixBot
    6. Dell Inpiron 3542 Motherboard  Replacement: step 6, image 1 of 2 Dell Inpiron 3542 Motherboard  Replacement: step 6, image 2 of 2
      • Use the plastic prying device to release the keyboard. Avoid from using excessive force to prevent damages.
      • Lift the keyboard.
      • Unplug the cable connecting the keyboard to the laptop.
      • Remove the keyboard.
      Ask FixBot
    7. Dell Inpiron 3542 Motherboard  Replacement: step 7, image 1 of 3 Dell Inpiron 3542 Motherboard  Replacement: step 7, image 2 of 3 Dell Inpiron 3542 Motherboard  Replacement: step 7, image 3 of 3
      • Unplug the touch pad cables located on the palm rest.
      • Remove the screws. (3 x M2.5 x 5mm)
      Ask FixBot
    8. Dell Inpiron 3542 Motherboard  Replacement: step 8, image 1 of 2 Dell Inpiron 3542 Motherboard  Replacement: step 8, image 2 of 2
      • Carefully unsnap the palm rest from the rest of the laptop.
      • Remove the palm rest.
      Ask FixBot
    9. Dell Inpiron 3542 Motherboard  Replacement: step 9, image 1 of 1
      • Unplug the cable that connects to the motherboard.
      • Remove the DC jack from the laptop.
      Ask FixBot
    10. Dell Inpiron 3542 Motherboard  Replacement: step 10, image 1 of 1
      • Loosen the cables on the antenna.
      Ask FixBot
    11. Dell Inpiron 3542 Motherboard  Replacement: step 11, image 1 of 2 Dell Inpiron 3542 Motherboard  Replacement: step 11, image 2 of 2
      • Remove the screws. (1 x M2 x 3mm)
      • Unplug the circuit board from the rest of the computer.
      Ask FixBot
    12. Dell Inpiron 3542 Motherboard  Replacement: step 12, image 1 of 1
      • Loosen the tape on the left side of the laptop.
      • Unplug the display cable.
      Ask FixBot
    13. Dell Inpiron 3542 Motherboard  Replacement: step 13, image 1 of 2 Dell Inpiron 3542 Motherboard  Replacement: step 13, image 2 of 2
      • Unplug the cable on the bottom part of the mother board.
      • Remove the cable on the right side of the motherboard. (3x M2.5 x 5mm)
      • Remove the motherboard from the laptop.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Congratulations on replacing the Motherboard on your Dell Inpiron 3542.
5 other people completed this guide.
Rachel lindsey
754 Reputation
5 Guides authored
1 Guide Comment
Anyone know where I can purchase a board for a Dell Inspiron 3542 in the UK?
Darrell Haslam - Reply Share
Past 24 Hours: 5
Past 7 Days: 30
Past 30 Days: 137
All Time: 4,602
