Dell G7 15-7588 RAM Replacement
    1. Dell G7 15-7588 RAM Replacement, RAM: step 1, image 1 of 2 Dell G7 15-7588 RAM Replacement, RAM: step 1, image 2 of 2
      • Use a Phillips #00 screwdriver to unscrew the 2 mm screw that secures the bottom cover.
      • This screw can not be fully removed from the bottom cover. It will only lift the back cover up the laptop up and allow it to be removed.
      • This will raise the bottom cover of the laptop centered around the screw, providing a easy point to remove the laptop back from later.
      Ask FixBot
    2. Dell G7 15-7588 RAM Replacement: step 2, image 1 of 1
      • Remove the bottom cover from the laptop by pulling back the cover.
      • It is recommended to start from where the screw near the top of the laptop lifts the cover.
      Ask FixBot
    3. Dell G7 15-7588 RAM Replacement: step 3, image 1 of 3 Dell G7 15-7588 RAM Replacement: step 3, image 2 of 3 Dell G7 15-7588 RAM Replacement: step 3, image 3 of 3
      • Use a Phillips #0 screwdriver to remove the three 2.5 mm screws from the battery brackets.
      Ask FixBot
    4. Dell G7 15-7588 RAM Replacement: step 4, image 1 of 1
      • Grab both sides of the battery connector.
      • Pull the battery connector straight back to disconnect it from the laptop.
      • This will completely disconnect the batter from the laptop.
      Ask FixBot
    5. Dell G7 15-7588 RAM Replacement: step 5, image 1 of 2 Dell G7 15-7588 RAM Replacement: step 5, image 2 of 2
      • Push the sides of the metal retention clips outward.
      • This will release the RAM from its locked state and cause it to rise upward, allowing for removal.
      • The same method is used for both pieces of RAM.
      Ask FixBot
    6. Dell G7 15-7588 RAM Replacement: step 6, image 1 of 2 Dell G7 15-7588 RAM Replacement: step 6, image 2 of 2
      • Remove the RAM from the laptop by pulling it up from the slot.
      Ask FixBot
Ryan Peschke
141 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 23
Past 30 Days: 89
All Time: 1,366
