Dell G15-5511 Gaming Back Cover Replacement
    1. Dell G15-5511 Gaming Back Cover Replacement, Unfasten the back cover: step 1, image 1 of 2 Dell G15-5511 Gaming Back Cover Replacement, Unfasten the back cover: step 1, image 2 of 2
      • For your safety, discharge the battery below 25% and power down your device before disassembly.
      • Use a Phillips #1 screwdriver to remove the four 6.8 mm-long screws that secure the cover.
      • Use a Phillips #1 screwdriver to loosen the four captive screws.
      Ask FixBot
    2. Dell G15-5511 Gaming Back Cover Replacement, Unclip the front corners: step 2, image 1 of 2 Dell G15-5511 Gaming Back Cover Replacement, Unclip the front corners: step 2, image 2 of 2
      • Insert an opening pick between the bottom-left corner of the back cover and the chassis.
      • Pry up to release the clips securing the back cover.
      • You'll hear a click whenever a clip is released.
      Ask FixBot
    3. Dell G15-5511 Gaming Back Cover Replacement: step 3, image 1 of 2 Dell G15-5511 Gaming Back Cover Replacement: step 3, image 2 of 2
      • Insert your opening pick again between the bottom-right corner of the back cover and the chassis.
      • Pry up to release the remaining clips securing the back cover.
      Ask FixBot
    4. Dell G15-5511 Gaming Back Cover Replacement, Remove the back cover: step 4, image 1 of 3 Dell G15-5511 Gaming Back Cover Replacement, Remove the back cover: step 4, image 2 of 3 Dell G15-5511 Gaming Back Cover Replacement, Remove the back cover: step 4, image 3 of 3
      • Grip the front of the back cover and lift it away from the laptop.
      • Pull the back cover towards you to disconnect the clips along the top of the back cover.
      • Remove the back cover.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Dell laptop answers community for help.
2 other people completed this guide.
Clay Eickemeyer
106,250 Reputation
472 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 88
All Time: 3,994
