Dell EMC PowerEdge R750 Server Fan Replacement
  1. Dell EMC PowerEdge R750 Server Fan Replacement, Server Fan: step 1, image 1 of 3 Dell EMC PowerEdge R750 Server Fan Replacement, Server Fan: step 1, image 2 of 3 Dell EMC PowerEdge R750 Server Fan Replacement, Server Fan: step 1, image 3 of 3
    • Gently slide or lift the cover off, exposing the internal components.
    Ask FixBot
  2. Dell EMC PowerEdge R750 Server Fan Replacement: step 2, image 1 of 3 Dell EMC PowerEdge R750 Server Fan Replacement: step 2, image 2 of 3 Dell EMC PowerEdge R750 Server Fan Replacement: step 2, image 3 of 3
    • Locate the fan(s) within the server.
    • Typically they are located near heat-sensitive components like the CPU or Power Supply. A visual inspection will help identify the malfunctioning fan.
    Ask FixBot
  3. Dell EMC PowerEdge R750 Server Fan Replacement: step 3, image 1 of 3 Dell EMC PowerEdge R750 Server Fan Replacement: step 3, image 2 of 3 Dell EMC PowerEdge R750 Server Fan Replacement: step 3, image 3 of 3
    • Release the clips holding the fan in place.
    • Keep the screws safe as you may need them to install the new fan.
    • Carefully lift the fan out of its slot. Take note of the positioning to ensure the replacement fan is aligned correctly.
    Ask FixBot
  4. Dell EMC PowerEdge R750 Server Fan Replacement: step 4, image 1 of 3 Dell EMC PowerEdge R750 Server Fan Replacement: step 4, image 2 of 3 Dell EMC PowerEdge R750 Server Fan Replacement: step 4, image 3 of 3
    • Place the new fan in the same position, ensuring it is aligned as the previous one.
    • Secure it by replacing the screws or clipping it into place.
    Ask FixBot
  5. Dell EMC PowerEdge R750 Server Fan Replacement: step 5, image 1 of 3 Dell EMC PowerEdge R750 Server Fan Replacement: step 5, image 2 of 3 Dell EMC PowerEdge R750 Server Fan Replacement: step 5, image 3 of 3
    • Now that the new fan is inserted correctly, make a visual verification that all parts look properly placed.
    Ask FixBot
  6. Dell EMC PowerEdge R750 Server Fan Replacement: step 6, image 1 of 3 Dell EMC PowerEdge R750 Server Fan Replacement: step 6, image 2 of 3 Dell EMC PowerEdge R750 Server Fan Replacement: step 6, image 3 of 3
    • Reattach the server's outer casting and tighten the screws.
    • Plug the server back in, power it on, and listen to the new fan to ensure it is running smoothly.
    Ask FixBot
Kristiana Romero
140 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 33
All Time: 474
