Dell E193FPc Motherboard Replacement
    1. Dell E193FPc Motherboard Replacement, Stand: step 1, image 1 of 1
      • Lay the monitor screen-down so the back screws are exposed.
      • Remove the four 11.9 mm Phillips #2 screws securing the stand to the back of the monitor.
      Ask FixBot
    2. Dell E193FPc Motherboard Replacement: step 2, image 1 of 1
      • Gently lift and pull away the stand at a slight angle away from the monitor.
      Ask FixBot
    1. Dell E193FPc Motherboard Replacement, Display Bezel: step 3, image 1 of 2 Dell E193FPc Motherboard Replacement, Display Bezel: step 3, image 2 of 2
      • Locate the two holes on the bottom of the monitor.
      • Insert a plastic opening tool or spudger into the holes and gently pry the plastic apart along the groove.
      • This task is much easier if two people pry simultaneously at each hole.
      • Continue prying along the entire edge of the monitor.
      Ask FixBot
    2. Dell E193FPc Motherboard Replacement: step 4, image 1 of 2 Dell E193FPc Motherboard Replacement: step 4, image 2 of 2
      • When finished prying, the plastic will partially fall away from the rest of the monitor.
      • Do not try to fully remove the front frame yet. The frame is still attached to the buttons.
      • While holding the frames together, carefully flip the monitor over so it faces screen down.
      • Gently lift and remove remove the rear case from the monitor.
      Ask FixBot
    3. Dell E193FPc Motherboard Replacement: step 5, image 1 of 3 Dell E193FPc Motherboard Replacement: step 5, image 2 of 3 Dell E193FPc Motherboard Replacement: step 5, image 3 of 3
      • Locate the green interface button board.
      • Remove the three 9.71 mm Phillips #2 screws holding the interface button board to the display bezel.
      • Lift the monitor interior away from the front cover.
      Ask FixBot
    1. Dell E193FPc Motherboard Replacement, Inverter Board: step 6, image 1 of 3 Dell E193FPc Motherboard Replacement, Inverter Board: step 6, image 2 of 3 Dell E193FPc Motherboard Replacement, Inverter Board: step 6, image 3 of 3
      • With the monitor facing down, remove the two 5.81 mm Phillips #2 screws on the right side of the metal casing.
      • With the monitor still facing down, remove the two 5.81 mm Phillips #2 screws on the left side of the casing.
      • Do attempt to pull apart the casing. There are still wires holding the front and back together.
      Ask FixBot
    2. Dell E193FPc Motherboard Replacement: step 7, image 1 of 1
      • Using a 5 mm nut driver, unscrew the VGA port's mounting screws from the metal casing.
      Ask FixBot
    3. Dell E193FPc Motherboard Replacement: step 8, image 1 of 1
      • With the monitor facing down, gently lift the back case away from the rest of the monitor to expose the inverter board and mother board.
      • Recall that the casing is still held together by several wires. Do not attempt to fully remove the back casing.
      Ask FixBot
    4. Dell E193FPc Motherboard Replacement: step 9, image 1 of 2 Dell E193FPc Motherboard Replacement: step 9, image 2 of 2
      • The inverter board is the smaller board in the corner.
      • Remove the three 7.69 mm Phillips #2 screws from the inverter board.
      • Remove the two 7.69 mm Phillips #2 grounding screws from the wire with the black connector.
      • Gently pull the inverter board away from the case. Note that the board is still connected to several components by wires.
      Ask FixBot
    5. Dell E193FPc Motherboard Replacement: step 10, image 1 of 2 Dell E193FPc Motherboard Replacement: step 10, image 2 of 2
      • There is a wire connecting the motherboard to the inverter board. Squeeze both sides of the connector and pull to remove it from the socket.
      • There is another wire connecting the button board to the inverter board. Remove the second white wire connector.
      • A third wire connects the inverter board to the screen circuit board. Remove the black wire connector.
      • The inverter board can now be fully removed.
      Ask FixBot
    1. Dell E193FPc Motherboard Replacement, Motherboard: step 11, image 1 of 1
      • With the monitor facing down, remove the 5.84 mm Phillips #2 screw from the metal sheet.
      • You can now open the device up. Be careful, there are still wires attached to the motherboard.
      Ask FixBot
    2. Dell E193FPc Motherboard Replacement: step 12, image 1 of 1
      • With the monitor facing down, lift the back cover up and lay it face up, exposing the motherboard.
      • Remove the five 7.7 mm Phillips #2 screws from the motherboard.
      Ask FixBot
    3. Dell E193FPc Motherboard Replacement: step 13, image 1 of 2 Dell E193FPc Motherboard Replacement: step 13, image 2 of 2
      Tool used on this step:
      Buy
      • Squeeze the plastic prong in the middle of the motherboard with a metal tweezer, while gently prying the other side with the plastic prying tool.
      • Be careful when using the metal tweezers. Make sure you do not make contact with any part that contains metal, for it may still have a charge. Discharge all capacitors.
      • This is easiest when the monitor is positioned such that motherboard is beneath the metal casing.
      Ask FixBot
    4. Dell E193FPc Motherboard Replacement: step 14, image 1 of 2 Dell E193FPc Motherboard Replacement: step 14, image 2 of 2
      • Remove the connector to the power outlet from the motherboard.
      • Remove the 4 connectors to the metal casing from the motherboard.
      • The motherboard can now be fully removed from the casing.
      Ask FixBot
Mackenzie Keane
523 Reputation
5 Guides authored
Cal Poly, Team 5-36, Amido Fall 2011 Member of Cal Poly, Team 5-36, Amido Fall 2011
CPSU-AMIDO-F11S5G36
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 9
Past 30 Days: 29
All Time: 4,293
