Dell Dimension 4600 Fan Replacement
Views: 6.8K
View statistics:
Past 24 Hours:
4
Past 7 Days:
23
Past 30 Days:
108
All Time:
6,787
Comments: 1
1 guide comment.
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 minutes
Difficulty: Easy
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Better Introduction
Improve this guide by completing or revising its introduction.
Introduction
Go to step 1 ↓
Use this guide to replace the fan inside of your Dell Dimension 4600.
    1. Dell Dimension 4600 Fan Replacement, Side Panel: step 1, image 1 of 1
      • Locate the case cover latch on the back of the computer.
      Ask FixBot
    2. Dell Dimension 4600 Fan Replacement: step 2, image 1 of 1
      • Using your index finger, slide and hold the cover latch down.
      • While holding the latch down, place your other hand flat on the side of the case and firmly shift the side panel to the left until it disengages.
      Ask FixBot
    3. Dell Dimension 4600 Fan Replacement: step 3, image 1 of 1
      • Grab the edge of the panel and slide it away from the case until it is removed.
      Ask FixBot
    1. Dell Dimension 4600 Fan Replacement, Fan: step 4, image 1 of 1
      • Lay the computer flat on it's side so that you are looking down at all of the components.
      • Locate the fan and its black, red, and white power cable.
      Ask FixBot
    2. Dell Dimension 4600 Fan Replacement: step 5, image 1 of 1
      • Follow the power cable to the motherboard connection and remove it by pressing down on the clip.
      Ask FixBot
    3. Dell Dimension 4600 Fan Replacement: step 6, image 1 of 1
      • Locate the release clip on the side of the fan and hold it down with your thumb.
      Ask FixBot
    4. Dell Dimension 4600 Fan Replacement: step 7, image 1 of 1
      • While holding the release clip down, look on the outside of the case where the fan lies.
      • Using the four black notches as a reference, slide the fan towards the open side releasing the fan.
      Ask FixBot
4 other people completed this guide.
Tim
76 Reputation
1 Guide authored
Cal Poly, Team 6-10, Regan Fall 2011 Member of Cal Poly, Team 6-10, Regan Fall 2011
CPSU-REGAN-F11S6G10
4 Members
72 Guides authored
1 Guide Comment
Thank you, the pictures are very good. My Dell 4600 had a green baffle that funneled the air through the heat sink fins. There is a little latch at the bottom which allows the this to swing open. Because the back of my PC is full of 13 years worth of cables, I did this without lying the PC down and without disconnecting the fan connector from the mother board. I am amazed at how quiet the PC is now.
pxcozzol - Reply Share
Past 24 Hours: 4
Past 7 Days: 23
Past 30 Days: 108
All Time: 6,787
