Up to 20% off select tools
Dell DJ Battery Replacement
Views: 2.3K
View statistics:
Past 24 Hours:
6
Past 7 Days:
20
Past 30 Days:
119
All Time:
2,251
Comments: 1
1 comment on steps.
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 25 minutes
Difficulty: Easy
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
Introduction
Go to step 1 ↓
If your battery is dead or just isn't properly holding a charge, follow this guide.
    1. Dell DJ Battery Replacement, Battery: step 1, image 1 of 3 Dell DJ Battery Replacement, Battery: step 1, image 2 of 3 Dell DJ Battery Replacement, Battery: step 1, image 3 of 3
      • Using the metal spudger, carefully slide it under the black rubber bottom to remove it.
      • Using a Phillips J000 head screw driver, unscrew the 4mm screws placed on the outer corners of the metal plate.
      • Again, take the metal spudger, placing it under the metal plate to take it off.
      Ask FixBot
    2. Dell DJ Battery Replacement: step 2, image 1 of 3 Dell DJ Battery Replacement: step 2, image 2 of 3 Dell DJ Battery Replacement: step 2, image 3 of 3
      • Once the metal plate is off, inspect the inside of the device to be sure the battery is plugged in and there's nothing blocking it.
      • Battery malfunction is often caused by internal components that are dirty. Be sure the battery clip is plugged in properly and then reassemble device. Hold the power button and start the device up.
      Ask FixBot
    3. Dell DJ Battery Replacement: step 3, image 1 of 2 Dell DJ Battery Replacement: step 3, image 2 of 2
      Tool used on this step:
      Buy
      • If the battery is still malfunctioning, carefully unplug the battery using tweezers.
      • Gently place the tweezers on either side of the batter to slide it out of the shell.
      Ask FixBot
    4. Dell DJ Battery Replacement: step 4, image 1 of 3 Dell DJ Battery Replacement: step 4, image 2 of 3 Dell DJ Battery Replacement: step 4, image 3 of 3
      • To replace the battery, simply insert a new one into the same slot and then plug in the end to the correct spot.
      • After the device is assembled, power the device on. The issue should be repaired.
      • If the device battery is still defective, a greater issue is the cause.
      Ask FixBot
Author
with
Brittany Abate
412 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 20
Past 30 Days: 119
All Time: 2,251
