Dell Chromebook 5190 Battery Replacement
  1. Dell Chromebook 5190 Battery Replacement, Battery: step 1, image 1 of 1
    • Before starting, please make sure you have disconnected and removed all devices populating the laptop's ports.
    • Remove the nine M2.5x7.5 screws located on the bottom side of the laptop.
    Ask FixBot
  2. Dell Chromebook 5190 Battery Replacement: step 2, image 1 of 3 Dell Chromebook 5190 Battery Replacement: step 2, image 2 of 3 Dell Chromebook 5190 Battery Replacement: step 2, image 3 of 3
    • Be cautious, the following instructions are to prevent cracking the base cover.
    • With the opening tool, pry open the upper left corner by the laptop hinge.
    • With the opening tool, pry open the upper right corner by the laptop hinge.
    • Lift off base cover.
    Ask FixBot
  3. Dell Chromebook 5190 Battery Replacement: step 3, image 1 of 2 Dell Chromebook 5190 Battery Replacement: step 3, image 2 of 2
    • Unscrew and remove the M2x3 screw holding the silver metal brackets labeled "Battery Bracket" located on the top left side of the battery.
    • Unscrew and remove the M2x3 screw holding the silver metal brackets labeled "Battery Bracket" located on the top right side of the battery.
    Ask FixBot
  4. Dell Chromebook 5190 Battery Replacement: step 4, image 1 of 2 Dell Chromebook 5190 Battery Replacement: step 4, image 2 of 2
    • Remove the clear adhesive tape on the system board from the battery cable from where it's seated above the battery.
    • Pull out the keyboard cable toward you to disconnect it.
    Ask FixBot
  5. Dell Chromebook 5190 Battery Replacement: step 5, image 1 of 2 Dell Chromebook 5190 Battery Replacement: step 5, image 2 of 2
    • Remove the black adhesive tape on the system board from the battery cable.
    • Dismount the cable from where it's seated above the battery.
    Ask FixBot
  6. Dell Chromebook 5190 Battery Replacement: step 6, image 1 of 3 Dell Chromebook 5190 Battery Replacement: step 6, image 2 of 3 Dell Chromebook 5190 Battery Replacement: step 6, image 3 of 3
    • Unscrew and remove the four M2x3 screws on each corner of the battery.
    • Dismount the battery.
    Ask FixBot
Denise Cano
617 Reputation
4 Guides authored
Gateway, Team 1-3, Pee Spring 2022 Member of Gateway, Team 1-3, Pee Spring 2022
GCC-PEE-S22S1G3
3 Members
5 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 7
Past 30 Days: 42
All Time: 976
