Dell Chromebook 3100 Battery Replacement
  1. Dell Chromebook 3100 Battery Replacement, Back Panel: step 1, image 1 of 3 Dell Chromebook 3100 Battery Replacement, Back Panel: step 1, image 2 of 3 Dell Chromebook 3100 Battery Replacement, Back Panel: step 1, image 3 of 3
    • Flip the laptop so the bottom is facing upwards.
    • Loosen the nine screws from the back panel using a Phillips #0 screwdriver.
    Ask FixBot
  2. Dell Chromebook 3100 Battery Replacement: step 2, image 1 of 1
    • Pry the back panel away from the rest of the laptop using an iFixit opening tool.
    Ask FixBot
  3. Dell Chromebook 3100 Battery Replacement, Battery: step 3, image 1 of 2 Dell Chromebook 3100 Battery Replacement, Battery: step 3, image 2 of 2
    • Remove the screws attached to the battery using a Phillips #0 screwdriver.
    • Disconnect the battery from the motherboard by gently pulling on the connector cable at the top of the battery.
    Ask FixBot
  4. Dell Chromebook 3100 Battery Replacement: step 4, image 1 of 1
    • Carefully remove the battery.
    Ask FixBot
To reassemble your device, follow these instructions in reverse order. For optimal performance, calibrate your newly installed battery after completing this guide.
Ben Brewer
85 Reputation
1 Guide authored
1 Guide Comment
a bit of a note the screws are captive soo no need to worry about the screws falling out of the back case but do yourself a favor with the battery screws and use a old pill bottle to store them for easy orgenization
Nathaniel Honomichl - Reply Share
Past 24 Hours: 3
Past 7 Days: 12
Past 30 Days: 43
All Time: 631
