Dell Chromebook 13-7310 IO Board Replacement
    1. Dell Chromebook 13-7310 IO Board Replacement, Back Cover: step 1, image 1 of 2 Dell Chromebook 13-7310 IO Board Replacement, Back Cover: step 1, image 2 of 2
      • Remove the eleven 3mm Phillips #1 screws.
      Ask FixBot
    2. Dell Chromebook 13-7310 IO Board Replacement: step 2, image 1 of 1
      • Use a plastic opening tool to gently remove the back panel.
      • It can be easier to pry open near a corner.
      Ask FixBot
    1. Dell Chromebook 13-7310 IO Board Replacement, Battery: step 3, image 1 of 1
      • Use your fingers to remove the connecting cable to the battery unit. Firmly grab the cord closest to the motherboard connection and pull straight back.
      Ask FixBot
    2. Dell Chromebook 13-7310 IO Board Replacement: step 4, image 1 of 1
      • Remove the four 2mm screws on the sides of the battery.
      Ask FixBot
    3. Dell Chromebook 13-7310 IO Board Replacement: step 5, image 1 of 1
      • To remove the battery, lift up on one side to get your fingers underneath and lift away.
      Ask FixBot
    1. Dell Chromebook 13-7310 IO Board Replacement, IO Board: step 6, image 1 of 1
      • Remove the single 2mm screw securing the IO board to the laptop.
      Ask FixBot
    2. Dell Chromebook 13-7310 IO Board Replacement: step 7, image 1 of 1
      • Pull up on the connector to release the IO board cable from the motherboard.
      • It may be easier to pull from the blue tab.
      Ask FixBot
    3. Dell Chromebook 13-7310 IO Board Replacement: step 8, image 1 of 1
      • Remove the IO board.
      Ask FixBot
Damon
181 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 30
All Time: 585
