Dell Chromebook 13 3380 Touchpad Replacement
  1. Dell Chromebook 13 3380 Touchpad Replacement, Battery: step 1, image 1 of 1
    • Flip over the device so it is face down.
    • Use a Phillips #0 screwdriver to remove all nine anchor screws.
  2. Dell Chromebook 13 3380 Touchpad Replacement: step 2, image 1 of 1
    • Gently remove the back cover.
    • You may need to use an opening tool to pry the cover away.
  3. Dell Chromebook 13 3380 Touchpad Replacement: step 3, image 1 of 1
    • Use the Phillips #0 screwdriver to remove the four screws attached to the battery.
  4. Dell Chromebook 13 3380 Touchpad Replacement: step 4, image 1 of 1
    • Unplug the flat flexible cable (FFC) connector from the circuit board.
  5. Dell Chromebook 13 3380 Touchpad Replacement: step 5, image 1 of 1
    • Remove the battery.
  6. Dell Chromebook 13 3380 Touchpad Replacement, Touchpad: step 6, image 1 of 2 Dell Chromebook 13 3380 Touchpad Replacement, Touchpad: step 6, image 2 of 2
    • Unscrew the touchpad.
  7. Dell Chromebook 13 3380 Touchpad Replacement: step 7, image 1 of 1
    • Unplug the ribbon.
    • Remove the touchpad.
Jessica M
94 Reputation
1 Guide authored
Texas Tech, Team 46-2, Johansen Fall 2025 Member of Texas Tech, Team 46-2, Johansen Fall 2025
TTU-JOHANSEN-F25S46G2
4 Members
4 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 11
All Time: 82
