Dell Chromebook 13 3380 Display Assembly Replacement
  1. Dell Chromebook 13 3380 Display Assembly Replacement, Display Assembly: step 1, image 1 of 1
    • Open the lid of the laptop.
    • Using a Phillips #0 screwdriver to remove four total 3.4 mm screws from the display, one from each corner.
    Ask FixBot
  2. Dell Chromebook 13 3380 Display Assembly Replacement: step 2, image 1 of 1
    • Release the plastic clips along the inside of the screen bezel using your hand.
    • Use a plastic prying tool or opening pick if needed.
    Ask FixBot
  3. Dell Chromebook 13 3380 Display Assembly Replacement: step 3, image 1 of 1
    • Use a Phillips #0 screwdriver to remove the three 3.5 mm screws from the bottom of the display.
    Ask FixBot
  4. Dell Chromebook 13 3380 Display Assembly Replacement: step 4, image 1 of 1
    • Use a Phillips #00 screwdriver to remove the four 1.2 mm screws holding the screen in place.
    Ask FixBot
  5. Dell Chromebook 13 3380 Display Assembly Replacement: step 5, image 1 of 1
    • Flip the display over on top of the keyboard.
    • Unplug the video cable.
    • Remove the display assembly.
    Ask FixBot
Cade Larson
250 Reputation
2 Guides authored
Texas Tech, Team 46-2, Johansen Fall 2025 Member of Texas Tech, Team 46-2, Johansen Fall 2025
TTU-JOHANSEN-F25S46G2
4 Members
4 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 16
All Time: 100
