Dell Chromebook 11 CB1C13 Bottom Cover Replacement
Views: 1.5K
View statistics:
Past 24 Hours:
2
Past 7 Days:
26
Past 30 Days:
103
All Time:
1,485
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
An essential step for any sort of replacement or repair that involves the inside of the device. This guide will show the procedure to take off the bottom cover of the laptop.
Parts
Tools
    1. Dell Chromebook 11 CB1C13 Bottom Cover  Replacement, Back Panel: step 1, image 1 of 3 Dell Chromebook 11 CB1C13 Bottom Cover  Replacement, Back Panel: step 1, image 2 of 3 Dell Chromebook 11 CB1C13 Bottom Cover  Replacement, Back Panel: step 1, image 3 of 3
      • Make sure that device is fully powered down before attempting to open the back case.
      • Remove all seven 8 mm Philips #0 screws from the back case with a Philips #0 screwdriver.
      • Once all seven screws are removed, you can pry the case off using your fingers or a plastic opening tool.
      Ask FixBot
Bryan Allen
272 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 26
Past 30 Days: 103
All Time: 1,485
