Up to 20% off select tools
Dell Axim X30 Screen Replacement
Views: 1.7K
View statistics:
Past 24 Hours:
3
Past 7 Days:
23
Past 30 Days:
96
All Time:
1,689
Comments: 0
Go to guide comments
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 20 minutes
Difficulty: Moderate
Slice and Dice
The steps in this guide should be split up and made into a series of prerequisite guides.
Tools
Introduction
Go to step 1 ↓
The replacement of the screen is not difficult. Following the steps outlined in this guideline, one should be able to remove the necessary parts to the device to quickly access the screen. Please note that some of the pull tabs located inside the motherboard require some force when removing and reinserting. Take caution to not rip these pieces!
    1. Dell Axim X30 Screen Replacement, Screen: step 1, image 1 of 3 Dell Axim X30 Screen Replacement, Screen: step 1, image 2 of 3 Dell Axim X30 Screen Replacement, Screen: step 1, image 3 of 3
      • Remove the four rubber feet with your fingers.
      Ask FixBot
    2. Dell Axim X30 Screen Replacement: step 2, image 1 of 2 Dell Axim X30 Screen Replacement: step 2, image 2 of 2
      • Trigger battery release by inserting a nylon spudger into the battery release tab.
      • Slide tab and pull upwards on the battery to remove. Use the finger slots near the battery.
      Ask FixBot
    3. Dell Axim X30 Screen Replacement: step 3, image 1 of 1
      • Remove the four 12.7mm screws under rubber feet with a JIS #0 screwdriver.
      Ask FixBot
    4. Dell Axim X30 Screen Replacement: step 4, image 1 of 1
      • Remove back panel with a plastic opening tool. Follow the edge of the device around the entire perimeter.
      • The back panel should just pop off.
      Ask FixBot
    5. Dell Axim X30 Screen Replacement: step 5, image 1 of 3 Dell Axim X30 Screen Replacement: step 5, image 2 of 3 Dell Axim X30 Screen Replacement: step 5, image 3 of 3
      • Disconnect ribbon cables.
      • You may need to use a little force to disconnect them.
      • Disconnect red and white wired connector for speaker and motherboard battery.
      Ask FixBot
    6. Dell Axim X30 Screen Replacement: step 6, image 1 of 2 Dell Axim X30 Screen Replacement: step 6, image 2 of 2
      • Remove three 12.7mm JIS #0 screws.
      Ask FixBot
    7. Dell Axim X30 Screen Replacement: step 7, image 1 of 1
      • Carefully remove motherboard.
      Ask FixBot
    8. Dell Axim X30 Screen Replacement: step 8, image 1 of 2 Dell Axim X30 Screen Replacement: step 8, image 2 of 2
      • Remove the two 9.6 mm screws by the speaker and green battery with a JIS #0 screwdriver.
      Ask FixBot
    9. Dell Axim X30 Screen Replacement: step 9, image 1 of 2 Dell Axim X30 Screen Replacement: step 9, image 2 of 2
      • Remove black plastic board.
      Ask FixBot
    10. Dell Axim X30 Screen Replacement: step 10, image 1 of 2 Dell Axim X30 Screen Replacement: step 10, image 2 of 2
      • Gently apply pressure on the right plastic frame by plastic clip marked on the picture.
      • Apply pressure to the bottom of the screen and press it towards you.
      • Remove screen from plastic case.
      Ask FixBot
Author
with
Peter Reilly
199 Reputation
1 Guide authored
IUPUI, Team S2-G5, Harley Spring 2018 Member of IUPUI, Team S2-G5, Harley Spring 2018
IUPUI-HARLEY-S18S2G5
3 Members
24 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 23
Past 30 Days: 96
All Time: 1,689
