Up to 20% off select tools
Dell Axim X30 Button Replacement
Views: 1.4K
View statistics:
Past 24 Hours:
3
Past 7 Days:
21
Past 30 Days:
100
All Time:
1,383
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 25 minutes
Difficulty: Moderate
Slice and Dice
The steps in this guide should be split up and made into a series of prerequisite guides.
Tools
Introduction
Go to step 1 ↓
The Dell Axim X30 has 5 buttons on the front of the device below the main screen. This guide will focus on the replacement of the home button, messaging button, navigator button, contacts button, and calendar button.
    1. Dell Axim X30 Button Replacement, Buttons: step 1, image 1 of 2 Dell Axim X30 Button Replacement, Buttons: step 1, image 2 of 2
      • Remove the four rubber feet with your fingers.
      Ask FixBot
    2. Dell Axim X30 Button Replacement: step 2, image 1 of 2 Dell Axim X30 Button Replacement: step 2, image 2 of 2
      • Insert the nylon spudger into the battery cover release slot to remove the battery from the device.
      Ask FixBot
    3. Dell Axim X30 Button Replacement: step 3, image 1 of 1
      • Remove four 12.7mm JIS #0 screws.
      Ask FixBot
    4. Dell Axim X30 Button Replacement: step 4, image 1 of 1
      • Remove the back panel with a plastic opening tool. Follow the edge of the device around the entire perimeter.
      • The back panel will pop off easily.
      Ask FixBot
    5. Dell Axim X30 Button Replacement: step 5, image 1 of 3 Dell Axim X30 Button Replacement: step 5, image 2 of 3 Dell Axim X30 Button Replacement: step 5, image 3 of 3
      • Disconnect ribbon cables.
      • You may need to use a little force to disconnect them.
      • Disconnect red and white wired connector for speaker and motherboard battery.
      Ask FixBot
    6. Dell Axim X30 Button Replacement: step 6, image 1 of 2 Dell Axim X30 Button Replacement: step 6, image 2 of 2
      • Remove three 12.7mm JIS #0 screws.
      Ask FixBot
    7. Dell Axim X30 Button Replacement: step 7, image 1 of 1
      • Carefully remove motherboard.
      Ask FixBot
    8. Dell Axim X30 Button Replacement: step 8, image 1 of 1
      • Remove the two 9.6 mm screws by the speaker and green battery with a JIS #0 screwdriver.
      Ask FixBot
    9. Dell Axim X30 Button Replacement: step 9, image 1 of 2 Dell Axim X30 Button Replacement: step 9, image 2 of 2
      • Remove black plastic board.
      Ask FixBot
    10. Dell Axim X30 Button Replacement: step 10, image 1 of 2 Dell Axim X30 Button Replacement: step 10, image 2 of 2
      • Remove grey and green membrane buttons.
      Ask FixBot
Author
with
Jonathan Gulley
189 Reputation
1 Guide authored
IUPUI, Team S2-G5, Harley Spring 2018 Member of IUPUI, Team S2-G5, Harley Spring 2018
IUPUI-HARLEY-S18S2G5
3 Members
24 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 21
Past 30 Days: 100
All Time: 1,383
