Dell Alienware M18x Memory Modules Replacement
    1. Dell Alienware M18x Memory Modules Replacement, Popping up the Memory Module: step 1, image 1 of 3 Dell Alienware M18x Memory Modules Replacement, Popping up the Memory Module: step 1, image 2 of 3 Dell Alienware M18x Memory Modules Replacement, Popping up the Memory Module: step 1, image 3 of 3
      • Follow the instructions in Before You Begin.
      • CAUTION: To prevent damage to the memory -module connector, do not use tools to spread the memory module securing clips.
      • Using your fingertips, spread apart the securing clips on each end of the memory-module connector until the memory module pops up.
      Ask FixBot
    2. Dell Alienware M18x Memory Modules Replacement, Align the Notch: step 2, image 1 of 2 Dell Alienware M18x Memory Modules Replacement, Align the Notch: step 2, image 2 of 2
      • Align the notch in the NEW memory module with the tab in the memory-module connector.
      Ask FixBot
    3. Dell Alienware M18x Memory Modules Replacement, Sliding the Memory Module: step 3, image 1 of 1
      • Slide the memory module into the connector at a 45-degree angle, and press the memory module down until it clicks into place. If you do not hear the click, remove the memory module and reinstall it.
      • NOTE: If the memory module is not installed properly, the computer may not boot.
      Ask FixBot
Terrence15
80,143 Reputation
441 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
45 Members
12,349 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 15
Past 30 Days: 50
All Time: 453
