Dell Alienware M18x Hard Drive Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
Past 7 Days:
14
Past 30 Days:
55
All Time:
1,100
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 - 40 minutes
Difficulty: Easy
Community-Contributed Guide
Introduction
Go to step 1 ↓
In this guide, we will show you how to remove and replace the Hard Drive.
Tools
    1. Dell Alienware M18x Hard Drive Replacement, Lifting the Connector Latch: step 1, image 1 of 1
      • WARNING: Before working inside your computer, read the safety information that shipped with your computer.
      • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
      • Lift the connector latch that secures the hard-drive cable to the connector on the system board, and then disconnect the hard-drive cable from the connector on the system board.
      Ask FixBot
    2. Dell Alienware M18x Hard Drive Replacement, Loosen the Screws: step 2, image 1 of 1
      • Loosen the four captive screws that secure the hard-drive assembly to the computer base.
      Ask FixBot
    3. Dell Alienware M18x Hard Drive Replacement, Lifting the Hard-Drive: step 3, image 1 of 1
      • Using the pull-tab, lift the hard-drive assembly out of the computer base.
      Ask FixBot
    4. Dell Alienware M18x Hard Drive Replacement, Disconnecting the Interposer: step 4, image 1 of 1
      • Disconnect the interposer from the hard drives.
      Ask FixBot
    5. Dell Alienware M18x Hard Drive Replacement, Remove the Screws: step 5, image 1 of 1
      • Remove the four screws that secure the primary hard drive (HDD 0) and lift the hard drive out of the hard -drive bracket.
      Ask FixBot
    6. Dell Alienware M18x Hard Drive Replacement, Remove the Screws: step 6, image 1 of 1
      • Remove the four screws that secure the secondary hard drive (HDD 1) and slide the hard drive out of the hard-drive bracket.
      • CAUTION: When the hard drive is not in the computer, store it in protective antistatic packaging (see "Protecting Against Electrostatic Discharge" in the safety instructions that shipped with your computer).
      Ask FixBot
    7. Dell Alienware M18x Hard Drive Replacement, Place the Primary Hard Drive: step 7, image 1 of 1
      • Place the primary hard drive (HDD0) in the hard-drive bracket.
      Ask FixBot
    8. Dell Alienware M18x Hard Drive Replacement, Sliding the Secondary Hard Drive: step 8, image 1 of 1
      • If applicable, slide the secondary hard drive into the hard-drive bracket.
      Ask FixBot
    9. Dell Alienware M18x Hard Drive Replacement, Replace the Four Screws: step 9, image 1 of 1
      • Replace the four screws that secure the primary hard drive (HDD 0).
      Ask FixBot
    10. Dell Alienware M18x Hard Drive Replacement, Replace the Four Screws: step 10, image 1 of 1
      • If applicable, replace the four screws that secure the secondary hard drive (HDD 1) to the hard-drive bracket.
      • Connect the interposer to the hard drives.
      Ask FixBot
    11. Dell Alienware M18x Hard Drive Replacement, Placing the Hard Drive Assembly: step 11, image 1 of 1
      • Place the hard-drive assembly in the computer base.
      Ask FixBot
    12. Dell Alienware M18x Hard Drive Replacement, Tighten the Screws: step 12, image 1 of 1
      • Tighten the four captive screws that secure the hard-drive assembly to the computer base.
      Ask FixBot
    13. Dell Alienware M18x Hard Drive Replacement, Connect the Hard-Drive Cable: step 13, image 1 of 1
      • Connect the hard-drive cable to the connector on the system board and press down on the connector latch to secure the cable.
      Ask FixBot
Terrence15
80,143 Reputation
441 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
45 Members
12,349 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 55
All Time: 1,100
