Dell Alienware M17x R4 Memory Modules Replacement
    1. Dell Alienware M17x R4 Memory Modules Replacement, Remove the Screws: step 1, image 1 of 1
      • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before You Begin.
      • Remove the screws that secure the memory-module cover to the palm rest assembly.
      Ask FixBot
    2. Dell Alienware M17x R4 Memory Modules Replacement, Popping Up the Memory Module: step 2, image 1 of 1
      • CAUTION: To prevent damage to the memory-module connector, do not use tools to spread the memory module securing clips.
      • Use your fingertips to carefully spread apart the securing clips on each end of the memory-module connector until the memory module pops up.
      Ask FixBot
    3. Dell Alienware M17x R4 Memory Modules Replacement, Removing the Memory Module: step 3, image 1 of 2 Dell Alienware M17x R4 Memory Modules Replacement, Removing the Memory Module: step 3, image 2 of 2
      • Remove the memory module from the memory-module connector.
      Ask FixBot
    4. Dell Alienware M17x R4 Memory Modules Replacement, Align the Notch: step 4, image 1 of 1
      • NOTE: If you need to install memory modules in two connectors, install a memory module in the lower connector before you install a memory module in the upper connector.
      • Align the notch in the NEW memory module with the tab on the memory-module connector.
      Ask FixBot
    5. Dell Alienware M17x R4 Memory Modules Replacement, Installing the Memory Module: step 5, image 1 of 1
      • Slide the memory module firmly into the connector at a 45-degree angle, and press the memory module down until it clicks into place. If you do not hear the click, remove the memory module and reinstall it.
      Ask FixBot
    6. Dell Alienware M17x R4 Memory Modules Replacement, Align the Screw Holes: step 6, image 1 of 1
      • NOTE: If the memory module is not installed properly, the computer may not boot.
      • Align the screw holes on the memory-module cover with the screw holes on the palm rest assembly.
      Ask FixBot
    7. Dell Alienware M17x R4 Memory Modules Replacement, Replace the Screws: step 7, image 1 of 1
      • Replace the screws that secure the memory-module cover to the palm rest assembly.
      Ask FixBot
Terrence15
80,143 Reputation
441 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
45 Members
12,349 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 60
All Time: 1,348
