Dell Alienware M17x R4 Display Assembly Replacement
    1. Dell Alienware M17x R4 Display Assembly Replacement, Loosen the Screws: step 1, image 1 of 1
      • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before You Begin.
      • Loosen the captive screws that secure the display cable to the system board.
      Ask FixBot
    2. Dell Alienware M17x R4 Display Assembly Replacement, Disconnecting the Display Cable: step 2, image 1 of 1
      • Using the pull-tab, pull the display cable to disconnect the display cable from the connector on the system board.
      Ask FixBot
    3. Dell Alienware M17x R4 Display Assembly Replacement, Disconnecting the Camera Cable: step 3, image 1 of 1
      • Disconnect the camera cable and infrared cable from the respective system board connectors.
      Ask FixBot
    4. Dell Alienware M17x R4 Display Assembly Replacement, Note the Routing: step 4, image 1 of 2 Dell Alienware M17x R4 Display Assembly Replacement, Note the Routing: step 4, image 2 of 2
      • Note the routing of the display cable, camera cable, infrared cable, wirelessHD card cable, Mini-Card antenna cables and remove the cables from the routing guides on the palm rest assembly.
      Ask FixBot
    5. Dell Alienware M17x R4 Display Assembly Replacement, Removing the Screws: step 5, image 1 of 1
      • Remove the screws that secure the display assembly to the computer base.
      Ask FixBot
    6. Dell Alienware M17x R4 Display Assembly Replacement, Lifting the Display Assembly: step 6, image 1 of 1
      • Lift the display assembly off the computer.
      Ask FixBot
    7. Dell Alienware M17x R4 Display Assembly Replacement, Placing the Display Assembly: step 7, image 1 of 2 Dell Alienware M17x R4 Display Assembly Replacement, Placing the Display Assembly: step 7, image 2 of 2
      • Place the NEW display assembly in position and replace the screws that secure the display assembly to the computer base.
      Ask FixBot
    8. Dell Alienware M17x R4 Display Assembly Replacement, Routing the Cables: step 8, image 1 of 2 Dell Alienware M17x R4 Display Assembly Replacement, Routing the Cables: step 8, image 2 of 2
      • Route the display cable, camera cable, infrared cable, wirelessHD card cable, and Mini-Card antenna cables through the routing guides on the palm rest assembly.
      Ask FixBot
    9. Dell Alienware M17x R4 Display Assembly Replacement, Connecting the Display Cable: step 9, image 1 of 1
      • Connect the display cable to the connector on the system board.
      Ask FixBot
    10. Dell Alienware M17x R4 Display Assembly Replacement, Tighten the Screws: step 10, image 1 of 1
      • Tighten the captive screws that secure the display cable to the system board.
      Ask FixBot
    11. Dell Alienware M17x R4 Display Assembly Replacement, Connecting the Cables: step 11, image 1 of 1
      • Connect the camera cable and infrared cable to the respective system board connectors.
      Ask FixBot
Terrence15
80,143 Reputation
441 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
45 Members
12,349 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 20
Past 30 Days: 84
All Time: 2,617
