Dell Alienware M11x R3 Battery Replacement
Views: 3.1K
View statistics:
Past 24 Hours:
6
Past 7 Days:
35
Past 30 Days:
127
All Time:
3,059
Comments: 1
1 comment on steps.
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Easy
Needs More Images
A few more images would make this guide's procedures crystal clear.
Missing Steps
Oops! This guide is currently missing one or more important steps.
Introduction
Go to step 1 ↓
This guide provides a concise, step-by-step process for replacing the battery in your Dell Alienware M11x R3 gaming laptop. Replacing the battery can help extend your laptop's life and improve your gaming experience. Before starting, gather the required tools and a compatible replacement battery, and remember to work on a clean, static-free surface while handling internal components carefully.
    1. Dell Alienware M11x R3 Battery Replacement, Lower Case: step 1, image 1 of 3 Dell Alienware M11x R3 Battery Replacement, Lower Case: step 1, image 2 of 3 Dell Alienware M11x R3 Battery Replacement, Lower Case: step 1, image 3 of 3
      • Loosen the eight retaining screws on the base of the computer with a small Phillips screwdriver.
      • The screws have retaining washers to hold them in place, so you don't have to remove them from the base plate.
      • Remove the bottom cover from the laptop.
      Ask FixBot
    1. Dell Alienware M11x R3 Battery Replacement, Battery: step 2, image 1 of 1
      • Ensure your Dell Alienware M11x R3 is turned off and disconnected from any power source. Close the lid and flip the laptop over to access the bottom panel.
      Ask FixBot
    2. Dell Alienware M11x R3 Battery Replacement: step 3, image 1 of 1
      • Caution: Ensure computer is completely powered down before attempting to remove the lower case of the computer.
      • Close the lid and flip the laptop over to access the bottom panel. Unscrew the two circled screws.
      Ask FixBot
    3. Dell Alienware M11x R3 Battery Replacement: step 4, image 1 of 1
      • After removing the two screws, gently lift up the battery with the small plastic tab attached.
      Ask FixBot
    4. Dell Alienware M11x R3 Battery Replacement: step 5, image 1 of 1
      • Caution: Do not attempt to fully remove the battery while the wire is still connected.
      • Lift the battery out of its casing while allowing the wire to remain attached.
      Ask FixBot
    5. Dell Alienware M11x R3 Battery Replacement: step 6, image 1 of 1
      • Behind the battery, locate the PD12 battery wire and gently unplug it.
      Ask FixBot
    6. Dell Alienware M11x R3 Battery Replacement: step 7, image 1 of 1
      • With the wire unplugged, and all of the screws taken out, you are free to remove the battery for replacement.
      • Remember to properly dispose of the old battery according to local regulations and recycling guidelines.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order using a new battery in place of the old one.
2 other people completed this guide.
Richard Maurice
534 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 35
Past 30 Days: 127
All Time: 3,059
