Dell Alienware M11x R3 2.5" Hard Drive Replacement
    1. Dell Alienware M11x R3  2.5" Hard Drive Replacement, Lower Case: step 1, image 1 of 3 Dell Alienware M11x R3  2.5" Hard Drive Replacement, Lower Case: step 1, image 2 of 3 Dell Alienware M11x R3  2.5" Hard Drive Replacement, Lower Case: step 1, image 3 of 3
      • Loosen the eight retaining screws on the base of the computer with a small Phillips screwdriver.
      • The screws have retaining washers to hold them in place, so you don't have to remove them from the base plate.
      • Remove the bottom cover from the laptop.
      Ask FixBot
    1. Dell Alienware M11x R3  2.5" Hard Drive Replacement, Hard Drive: step 2, image 1 of 1
      • Remove the three screws attaching the hard drive tray to the laptop.
      Ask FixBot
    2. Dell Alienware M11x R3  2.5" Hard Drive Replacement: step 3, image 1 of 1
      • Grasp the plastic tab provided, and gently pull up. This will unplug the drive from the laptop.
      Ask FixBot
    3. Dell Alienware M11x R3  2.5" Hard Drive Replacement: step 4, image 1 of 2 Dell Alienware M11x R3  2.5" Hard Drive Replacement: step 4, image 2 of 2
      • On both sides of the cage, there are two screws you have to unscrew to be able to remove the SSD.
      Ask FixBot
    4. Dell Alienware M11x R3  2.5" Hard Drive Replacement: step 5, image 1 of 2 Dell Alienware M11x R3  2.5" Hard Drive Replacement: step 5, image 2 of 2
      • Finally, remove the L connector for the hard drive. You will need to put this on your new hard drive.
      • Make sure that the SSD you bought to replace this one has the same connections. I.e. able to connect to a SATA cord.
      Ask FixBot
Richard Maurice
534 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 25
Past 30 Days: 96
All Time: 2,203
