Dell Alienware Aurora R5 SSD Replacement
  1. Dell Alienware Aurora R5 SSD Replacement, SSD: step 1, image 1 of 2 Dell Alienware Aurora R5 SSD Replacement, SSD: step 1, image 2 of 2
    • Power off the computer.
    • To ensure the PC is completely off, remove the cables at the back of the PC.
    Ask FixBot
  2. Dell Alienware Aurora R5 SSD Replacement: step 2, image 1 of 3 Dell Alienware Aurora R5 SSD Replacement: step 2, image 2 of 3 Dell Alienware Aurora R5 SSD Replacement: step 2, image 3 of 3
    • Lift the black latch at the back of the PC to pop open the side cover.
    • Carefully remove the side cover by lifting it up.
    Ask FixBot
  3. Dell Alienware Aurora R5 SSD Replacement: step 3, image 1 of 2 Dell Alienware Aurora R5 SSD Replacement: step 3, image 2 of 2
    • Unlock both tabs on the back of the PC by pushing them up.
    • Remove the power supply latch to get access to the inside.
    Ask FixBot
  4. Dell Alienware Aurora R5 SSD Replacement: step 4, image 1 of 3 Dell Alienware Aurora R5 SSD Replacement: step 4, image 2 of 3 Dell Alienware Aurora R5 SSD Replacement: step 4, image 3 of 3
    • Remove the black plastic part by pushing it down and then pulling it towards you.
    • Unlock the blue latch and pull to remove the graphics card.
    Ask FixBot
  5. Dell Alienware Aurora R5 SSD Replacement: step 5, image 1 of 3 Dell Alienware Aurora R5 SSD Replacement: step 5, image 2 of 3 Dell Alienware Aurora R5 SSD Replacement: step 5, image 3 of 3
    • Use the Phillips #1 screwdriver to remove the 3.7 mm screw and remove the old M2 SSD.
    Ask FixBot
Ensure that you tightly screwed on the M2 SSD and that you inserted the graphics card back to its position so that the PC runs smoothly with no problems. Once you have completed all the steps and reconnected the cables you have successfully replaced the NVMe M2 SSD and your PC is ready to be turned on!
5 other people completed this guide.
Sarah Mohammed
232 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 51
All Time: 4,161
