Dell Alienware 18 Coin-Cell Battery Replacement
    1. Dell Alienware 18 Coin-Cell Battery Replacement, Before You Begin: step 1, image 1 of 1
      • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before You Begin.
      Ask FixBot
    2. Dell Alienware 18 Coin-Cell Battery Replacement, Remove the base cover screws: step 2, image 1 of 1
      • Use a Phillips screwdriver to remove the three screws securing the base cover.
      Ask FixBot
    3. Dell Alienware 18 Coin-Cell Battery Replacement, Slide the Cover: step 3, image 1 of 1
      • Slide the base cover towards the rear of the computer and lift it off the computer base.
      Ask FixBot
    1. Dell Alienware 18 Coin-Cell Battery Replacement, Disconnecting the Coin-Cell Battery: step 4, image 1 of 1
      • WARNING: The battery may explode if installed incorrectly. Replace the battery only with the same or equivalent type. Discard used batteries according to the manufacturer’s instructions.
      • CAUTION: Removing the coin-cell battery resets the BIOS settings to default. It is recommended that you note the BIOS settings before removing the coin-cell battery.
      • Disconnect the coin-cell battery cable from its connector on the system board.
      Ask FixBot
    2. Dell Alienware 18 Coin-Cell Battery Replacement, Removing the Coin-Cell Battery: step 5, image 1 of 1
      • Remove the coin-cell battery cable from the routing guides on the computer base.
      Ask FixBot
    3. Dell Alienware 18 Coin-Cell Battery Replacement, Prying the Coin-Cell Battery: step 6, image 1 of 1
      • Pry up the coin-cell battery from the slot on the system board.
      Ask FixBot
    4. Dell Alienware 18 Coin-Cell Battery Replacement, Placing Coin-Cell Battery: step 7, image 1 of 1
      • Place the NEW coin-cell battery into the slot and press gently to adhere it to the computer base.
      Ask FixBot
    5. Dell Alienware 18 Coin-Cell Battery Replacement, Routing the Coin-Cell Battery Cable: step 8, image 1 of 1
      • Route the coin-cell battery cable through the routing guides on the computer base.
      Ask FixBot
    6. Dell Alienware 18 Coin-Cell Battery Replacement, Connecting Coin-Cell Battery: step 9, image 1 of 1
      • Connect the coin-cell battery cable to its connector on the system board.
      Ask FixBot
Finish Line
darrius
5,213 Reputation
30 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
45 Members
12,349 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 20
Past 30 Days: 67
All Time: 998
