Dell Alienware 15 R3 Wi-Fi Card Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
3
Past 7 Days:
24
Past 30 Days:
81
All Time:
1,100
Comments: 4
4 comments on steps.
Completed: 0
Favorites: 0
Time Required: 30 - 45 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Needs More Images
A few more images would make this guide's procedures crystal clear.
Inconsistent Images
Updating the images on this guide to be more consistent with the prerequisites would increase its awesomeness.
Better Introduction
Improve this guide by completing or revising its introduction.
Introduction
Go to step 1 ↓
If you need to replace the Wi-Fi card from your Dell Alienware 15 R3, follow this guide.
Tools
    1. Dell Alienware 15 R3 Wi-Fi Card Replacement, Back Case: step 1, image 1 of 3 Dell Alienware 15 R3 Wi-Fi Card Replacement, Back Case: step 1, image 2 of 3 Dell Alienware 15 R3 Wi-Fi Card Replacement, Back Case: step 1, image 3 of 3
      • Before you begin, turn off the laptop and unplug the charger.
      • Flip the laptop over so that the backside is facing up.
      • Use a Phillips #00 screwdriver to remove the six 13.0 mm screws from the sides of the back case.
      • Use a Phillips #00 screwdriver to remove one 5.0 mm screw from the back of the laptop.
      Ask FixBot
    2. Dell Alienware 15 R3 Wi-Fi Card Replacement: step 2, image 1 of 1
      • Use the opening tool to pry the back case from the computer.
      • Use the opening tool and work your way around the perimeter of the back case to gently release the clips.
      • Start from the black vent for an easier removal.
      • Lift the back case off of the laptop.
      Ask FixBot
    1. Dell Alienware 15 R3 Wi-Fi Card Replacement, Cover Assembly: step 3, image 1 of 1
      • Use a Phillips #00 screwdriver to remove two screws from the side of the laptop.
      Ask FixBot
    2. Dell Alienware 15 R3 Wi-Fi Card Replacement: step 4, image 1 of 2 Dell Alienware 15 R3 Wi-Fi Card Replacement: step 4, image 2 of 2
      • Use an opening tool to release the four tabs from the hinge cover and gently pry it off.
      Ask FixBot
    3. Dell Alienware 15 R3 Wi-Fi Card Replacement: step 5, image 1 of 3 Dell Alienware 15 R3 Wi-Fi Card Replacement: step 5, image 2 of 3 Dell Alienware 15 R3 Wi-Fi Card Replacement: step 5, image 3 of 3
      • Use a Phillips #00 screwdriver to remove 10 screws from the chassis.
      • Use a spudger or opening tool to remove the chassis and reveal the battery, fan, motherboard, and other components.
      Ask FixBot
    1. Dell Alienware 15 R3 Wi-Fi Card Replacement, Wi-Fi Card: step 6, image 1 of 3 Dell Alienware 15 R3 Wi-Fi Card Replacement, Wi-Fi Card: step 6, image 2 of 3 Dell Alienware 15 R3 Wi-Fi Card Replacement, Wi-Fi Card: step 6, image 3 of 3
      • Open the flap to reveal the Wi-Fi card.
      • Use the Phillips #00 screwdriver to remove the screw securing the Wi-Fi card.
      • Use a spudger to detach the coaxial cables from the Wi-Fi card.
      • Be careful when detaching these cable connectors from the Wi-Fi card. The base of the connectors are prone to break off.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 24
Past 30 Days: 81
All Time: 1,100
