Dell Alienware 15 R3 SSD Replacement
    1. Dell Alienware 15 R3 SSD Replacement, Back Case: step 1, image 1 of 3 Dell Alienware 15 R3 SSD Replacement, Back Case: step 1, image 2 of 3 Dell Alienware 15 R3 SSD Replacement, Back Case: step 1, image 3 of 3
      • Before you begin, turn off the laptop and unplug the charger.
      • Flip the laptop over so that the backside is facing up.
      • Use a Phillips #00 screwdriver to remove the six 13.0 mm screws from the sides of the back case.
      • Use a Phillips #00 screwdriver to remove one 5.0 mm screw from the back of the laptop.
      Ask FixBot
    2. Dell Alienware 15 R3 SSD Replacement: step 2, image 1 of 1
      • Use the opening tool to pry the back case from the computer.
      • Use the opening tool and work your way around the perimeter of the back case to gently release the clips.
      • Start from the black vent for an easier removal.
      • Lift the back case off of the laptop.
      Ask FixBot
    1. Dell Alienware 15 R3 SSD Replacement, SSD: step 3, image 1 of 1
      • Use the Phillips #00 to remove the 3.0 mm screws that secure the cover of the SSD.
      • Remove the cover from the SSD.
      • The cover is not pictured.
      • To prevent losing data, do NOT remove the SSD while the computer is on or in sleep mode.
      • Slide the old SSD card out of the slot.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 28
Past 30 Days: 85
All Time: 1,054
