Up to 20% off select tools
Dell Alienware 15 R3 RAM Replacement
Views: 1K
View statistics:
Past 24 Hours:
Past 7 Days:
13
Past 30 Days:
72
All Time:
1,046
Comments: 1
1 comment on steps.
Completed: 0
Favorites: 0
Time Required: 15 - 20 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Needs More Images
A few more images would make this guide's procedures crystal clear.
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
Introduction
Go to step 1 ↓
This is a guide that will help you when it comes to replacing the RAM on a Dell Alienware 15 R3 laptop.
Before beginning this repair, turn off the laptop and unplug it from the charging cord.
    1. Dell Alienware 15 R3 RAM Replacement, Back Case: step 1, image 1 of 3 Dell Alienware 15 R3 RAM Replacement, Back Case: step 1, image 2 of 3 Dell Alienware 15 R3 RAM Replacement, Back Case: step 1, image 3 of 3
      • Before you begin, turn off the laptop and unplug the charger.
      • Flip the laptop over so that the backside is facing up.
      • Use a Phillips #00 screwdriver to remove the six 13.0 mm screws from the sides of the back case.
      • Use a Phillips #00 screwdriver to remove one 5.0 mm screw from the back of the laptop.
      Ask FixBot
    2. Dell Alienware 15 R3 RAM Replacement: step 2, image 1 of 1
      • Use the opening tool to pry the back case from the computer.
      • Use the opening tool and work your way around the perimeter of the back case to gently release the clips.
      • Start from the black vent for an easier removal.
      • Lift the back case off of the laptop.
      Ask FixBot
    1. Dell Alienware 15 R3 RAM Replacement, RAM: step 3, image 1 of 1
      • To remove the old RAM sticks, push the metal arms out to the side, using an opening tool or your fingers.
      • Slide the RAM stick out at a 45 degree angle.
      • The RAM sticks are not pictured in this device.
      • To place the new RAM stick, insert it at a 45 degree angle and push it down gently. The metal sides will latch if they are in the correct position.
      Ask FixBot
Author
with
Jake Nelson
642 Reputation
7 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 72
All Time: 1,046
