Dell Alienware 15 R3 Motherboard Replacement
    1. Dell Alienware 15 R3 Motherboard Replacement, Back Case: step 1, image 1 of 3 Dell Alienware 15 R3 Motherboard Replacement, Back Case: step 1, image 2 of 3 Dell Alienware 15 R3 Motherboard Replacement, Back Case: step 1, image 3 of 3
      • Before you begin, turn off the laptop and unplug the charger.
      • Flip the laptop over so that the backside is facing up.
      • Use a Phillips #00 screwdriver to remove the six 13.0 mm screws from the sides of the back case.
      • Use a Phillips #00 screwdriver to remove one 5.0 mm screw from the back of the laptop.
      Ask FixBot
    2. Dell Alienware 15 R3 Motherboard Replacement: step 2, image 1 of 1
      • Use the opening tool to pry the back case from the computer.
      • Use the opening tool and work your way around the perimeter of the back case to gently release the clips.
      • Start from the black vent for an easier removal.
      • Lift the back case off of the laptop.
      Ask FixBot
    1. Dell Alienware 15 R3 Motherboard Replacement, Cover Assembly: step 3, image 1 of 1
      • Use a Phillips #00 screwdriver to remove two screws from the side of the laptop.
      Ask FixBot
    2. Dell Alienware 15 R3 Motherboard Replacement: step 4, image 1 of 2 Dell Alienware 15 R3 Motherboard Replacement: step 4, image 2 of 2
      • Use an opening tool to release the four tabs from the hinge cover and gently pry it off.
      Ask FixBot
    3. Dell Alienware 15 R3 Motherboard Replacement: step 5, image 1 of 3 Dell Alienware 15 R3 Motherboard Replacement: step 5, image 2 of 3 Dell Alienware 15 R3 Motherboard Replacement: step 5, image 3 of 3
      • Use a Phillips #00 screwdriver to remove 10 screws from the chassis.
      • Use a spudger or opening tool to remove the chassis and reveal the battery, fan, motherboard, and other components.
      Ask FixBot
    1. Dell Alienware 15 R3 Motherboard Replacement, Motherboard: step 6, image 1 of 1
      • Before you begin, disconnect the battery cable from the motherboard. Use the tip of a spudger or your fingernail to flip up the small locking flap. Then, you can safely pull the battery cable out.
      • Use a Phillips #00 screwdriver to remove the eleven screws connecting the fan to the motherboard.
      Ask FixBot
    2. Dell Alienware 15 R3 Motherboard Replacement: step 7, image 1 of 2 Dell Alienware 15 R3 Motherboard Replacement: step 7, image 2 of 2
      • Detach the ribbon cable connecting the heat sink to the motherboard.
      • Pull the heat sink off of the fan.
      • Be careful as you lift it off the fan so it doesn't bend.
      Ask FixBot
    3. Dell Alienware 15 R3 Motherboard Replacement: step 8, image 1 of 1
      • Use a Phillips #00 screwdriver to remove the eight screws from the motherboard.
      • Detach the remaining ribbon cables from the motherboard.
      • Remove the motherboard from the laptop.
      Ask FixBot
2 other people completed this guide.
3 Guide Comments
This guide completely skips disengaging the battery, which should be done before any components, and it should be plugged back in last.
Paul Wilson - Reply Share
Well, anyone in their right mind, would know that is the 1st thing to do. Give him credit for a great picturess of disassembling... :-)
Actually "Step 6" tells you to do just that !!!
Stephen Hart - Reply Share
Do NOT follow this guide. It completely skips important steps, specifically removal of the ribbon cable for the power button and display.
Alfonso Arriaga - Reply Share
Past 24 Hours: 3
Past 7 Days: 37
Past 30 Days: 122
All Time: 2,719
