Dell Alienware 15 R3 Battery Replacement
    1. Dell Alienware 15 R3 Battery Replacement, Back Case: step 1, image 1 of 3 Dell Alienware 15 R3 Battery Replacement, Back Case: step 1, image 2 of 3 Dell Alienware 15 R3 Battery Replacement, Back Case: step 1, image 3 of 3
      • Before you begin, turn off the laptop and unplug the charger.
      • Flip the laptop over so that the backside is facing up.
      • Use a Phillips #00 screwdriver to remove the six 13.0 mm screws from the sides of the back case.
      • Use a Phillips #00 screwdriver to remove one 5.0 mm screw from the back of the laptop.
      Ask FixBot
    2. Dell Alienware 15 R3 Battery Replacement: step 2, image 1 of 1
      • Use the opening tool to pry the back case from the computer.
      • Use the opening tool and work your way around the perimeter of the back case to gently release the clips.
      • Start from the black vent for an easier removal.
      • Lift the back case off of the laptop.
      Ask FixBot
    1. Dell Alienware 15 R3 Battery Replacement, Cover Assembly: step 3, image 1 of 1
      • Use a Phillips #00 screwdriver to remove two screws from the side of the laptop.
      Ask FixBot
    2. Dell Alienware 15 R3 Battery Replacement: step 4, image 1 of 2 Dell Alienware 15 R3 Battery Replacement: step 4, image 2 of 2
      • Use an opening tool to release the four tabs from the hinge cover and gently pry it off.
      Ask FixBot
    3. Dell Alienware 15 R3 Battery Replacement: step 5, image 1 of 3 Dell Alienware 15 R3 Battery Replacement: step 5, image 2 of 3 Dell Alienware 15 R3 Battery Replacement: step 5, image 3 of 3
      • Use a Phillips #00 screwdriver to remove 10 screws from the chassis.
      • Use a spudger or opening tool to remove the chassis and reveal the battery, fan, motherboard, and other components.
      Ask FixBot
    1. Dell Alienware 15 R3 Battery Replacement, Battery: step 6, image 1 of 1
      • Use a Phillips #00 screwdriver to remove the 5.0 mm screw that is securing the battery to the palm rest assembly.
      Ask FixBot
    2. Dell Alienware 15 R3 Battery Replacement: step 7, image 1 of 3 Dell Alienware 15 R3 Battery Replacement: step 7, image 2 of 3 Dell Alienware 15 R3 Battery Replacement: step 7, image 3 of 3
      • To the upper right of the battery is a connecting cable. Gently disconnect it from the palm rest assembly.
      • Confirm nothing else is connected to the battery and lift the battery completely off the palm rest assembly.
      Ask FixBot
2 other people completed this guide.
2 Guide Comments
does not seem to be for my alienware r3 15 inch
Craig Anderson - Reply Share
step 5 - you need to unscrew 10 screws, not 9. You missed the one in the center.
Mike Kravchenko - Reply Share
Past 24 Hours: 7
Past 7 Days: 35
Past 30 Days: 217
All Time: 10,990
