Dell Alienware 15 R3 Back Case Replacement
    1. Dell Alienware 15 R3 Back Case Replacement, Back Case: step 1, image 1 of 3 Dell Alienware 15 R3 Back Case Replacement, Back Case: step 1, image 2 of 3 Dell Alienware 15 R3 Back Case Replacement, Back Case: step 1, image 3 of 3
      • Before you begin, turn off the laptop and unplug the charger.
      • Flip the laptop over so that the backside is facing up.
      • Use a Phillips #00 screwdriver to remove the six 13.0 mm screws from the sides of the back case.
      • Use a Phillips #00 screwdriver to remove one 5.0 mm screw from the back of the laptop.
      Ask FixBot
    2. Dell Alienware 15 R3 Back Case Replacement: step 2, image 1 of 1
      • Use the opening tool to pry the back case from the computer.
      • Use the opening tool and work your way around the perimeter of the back case to gently release the clips.
      • Start from the black vent for an easier removal.
      • Lift the back case off of the laptop.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 15
Past 30 Days: 68
All Time: 808
