Dell Alienware 14 Power-Button Board Replacement
    1. Dell Alienware 14 Power-Button Board Replacement, Close the Display: step 1, image 1 of 1
      • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before You Begin. . After working inside your computer, follow the instructions in "After Working Inside Your Computer".
      • Close the display, and turn the computer over.
      Ask FixBot
    2. Dell Alienware 14 Power-Button Board Replacement, Remove the Screws: step 2, image 1 of 2 Dell Alienware 14 Power-Button Board Replacement, Remove the Screws: step 2, image 2 of 2
      • Remove the screws that secure the base cover to the computer base.
      Ask FixBot
    3. Dell Alienware 14 Power-Button Board Replacement, Slide and Lift the Base Cover: step 3, image 1 of 1
      • Slide and lift the base cover off the computer base.
      Ask FixBot
    4. Dell Alienware 14 Power-Button Board Replacement, Align the Tabs: step 4, image 1 of 1
      • Align the tabs on the NEW base cover with the slots on the computer base and slide the base cover into place.
      Ask FixBot
    5. Dell Alienware 14 Power-Button Board Replacement, Replace the Screws: step 5, image 1 of 1
      • Replace the screws that secure the base cover to the computer base.
      Ask FixBot
    6. Dell Alienware 14 Power-Button Board Replacement, Turn the Computer Over: step 6, image 1 of 1
      • Turn the computer over and open the display.
      Ask FixBot
    1. Dell Alienware 14 Power-Button Board Replacement, Disconnecting the Battery Cable: step 7, image 1 of 1
      Ask FixBot
    2. Dell Alienware 14 Power-Button Board Replacement, Remove the Screws: step 8, image 1 of 1
      • Remove the screws that secure the battery to the computer base.
      Ask FixBot
    3. Dell Alienware 14 Power-Button Board Replacement, Using the Battery Cable: step 9, image 1 of 1
      • Using the battery cable, lift the battery and release it from the tabs on the computer base.
      Ask FixBot
    4. Dell Alienware 14 Power-Button Board Replacement, Turn the Computer Over: step 10, image 1 of 1
      • Turn the computer over and open the display as far as possible.
      Ask FixBot
    5. Dell Alienware 14 Power-Button Board Replacement, The Power Button: step 11, image 1 of 1
      • Press and hold the power button for five seconds to ground the system board.
      Ask FixBot
      • Close the display and turn the computer over.
      Ask FixBot
    6. Dell Alienware 14 Power-Button Board Replacement, Align the Tabs: step 13, image 1 of 1
      • Align the tabs on the NEW battery with the slots on the computer base.
      Ask FixBot
    7. Dell Alienware 14 Power-Button Board Replacement, Align the Screw Holes: step 14, image 1 of 1
      • Align the screw holes on the battery with the screw holes on the computer base.
      Ask FixBot
    8. Dell Alienware 14 Power-Button Board Replacement, Replace the Screws: step 15, image 1 of 1
      • Replace the screws that secure the battery to the computer base.
      Ask FixBot
    9. Dell Alienware 14 Power-Button Board Replacement, Connect the Battery Cable: step 16, image 1 of 1
      • Connect the battery cable to the system-board connector.
      Ask FixBot
    1. Dell Alienware 14 Power-Button Board Replacement, Remove the Screws: step 17, image 1 of 2 Dell Alienware 14 Power-Button Board Replacement, Remove the Screws: step 17, image 2 of 2
      • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
      • CAUTION: To avoid data loss, do not remove the hard drive while the computer is On or in Sleep state.
      • CAUTION: Hard drives are extremely fragile. Exercise care when handling the hard drive.
      • NOTE: The secondary hard-drive or solid-state drive is optional and can be installed in the optical drive bay.
      • Remove the screws that secure the secondary hard-drive assembly to the computer base.
      Ask FixBot
    2. Dell Alienware 14 Power-Button Board Replacement, Lifting the Secondary Hard-Drive: step 18, image 1 of 3 Dell Alienware 14 Power-Button Board Replacement, Lifting the Secondary Hard-Drive: step 18, image 2 of 3 Dell Alienware 14 Power-Button Board Replacement, Lifting the Secondary Hard-Drive: step 18, image 3 of 3
      • Carefully lift the secondary hard-drive assembly and then lift the latches to release the secondary hard-drive cable from the system-board connector.
      Ask FixBot
    3. Dell Alienware 14 Power-Button Board Replacement, Lifting the Hard Drive: step 19, image 1 of 1
      • Lift the secondary hard-drive assembly off the computer base.
      Ask FixBot
    4. Dell Alienware 14 Power-Button Board Replacement, Turn the Assembly Over: step 20, image 1 of 1
      • Turn the secondary hard-drive assembly over.
      Ask FixBot
    5. Dell Alienware 14 Power-Button Board Replacement, Remove the Screw: step 21, image 1 of 1
      • Remove the screw that secures the secondary hard-drive assembly to the main bracket.
      Ask FixBot
    6. Dell Alienware 14 Power-Button Board Replacement, Remove the Screws: step 22, image 1 of 1
      • Remove the screws that secure the secondary hard-drive to the secondary hard-drive bracket.
      Ask FixBot
    7. Dell Alienware 14 Power-Button Board Replacement, Slide and Lift the Hard-Drive: step 23, image 1 of 2 Dell Alienware 14 Power-Button Board Replacement, Slide and Lift the Hard-Drive: step 23, image 2 of 2
      • Slide and lift the secondary hard-drive off the secondary hard-drive bracket.
      Ask FixBot
    8. Dell Alienware 14 Power-Button Board Replacement, Disconnect the Interposer: step 24, image 1 of 2 Dell Alienware 14 Power-Button Board Replacement, Disconnect the Interposer: step 24, image 2 of 2
      • Disconnect the interposer from the secondary hard-drive connector.
      Ask FixBot
    9. Dell Alienware 14 Power-Button Board Replacement, Connect the Interposer: step 25, image 1 of 1
      • Connect the interposer to the secondary hard-drive connector.
      Ask FixBot
    10. Dell Alienware 14 Power-Button Board Replacement, Placing the Secondary Hard-Drive: step 26, image 1 of 1
      • Place the NEW secondary hard-drive in the secondary hard-drive bracket.
      Ask FixBot
    11. Dell Alienware 14 Power-Button Board Replacement, Align the Screw Holes: step 27, image 1 of 1
      • Align the screw holes on the secondary hard-drive with the screw holes on the secondary hard-drive bracket.
      Ask FixBot
    12. Dell Alienware 14 Power-Button Board Replacement, Replace the Screws: step 28, image 1 of 1
      • Replace the screws that secure the secondary hard-drive to the secondary hard-drive bracket.
      Ask FixBot
    13. Dell Alienware 14 Power-Button Board Replacement, Align the Screw Hole: step 29, image 1 of 1
      • Align the screw hole on the secondary hard-drive assembly with the screw hole on the main bracket.
      Ask FixBot
    14. Dell Alienware 14 Power-Button Board Replacement, Replace the Screw: step 30, image 1 of 1
      • Replace the screw that secures the secondary hard-drive assembly to the main bracket.
      Ask FixBot
    15. Dell Alienware 14 Power-Button Board Replacement, Turn the Hard-Drive Assembly Over: step 31, image 1 of 1
      Ask FixBot
    16. Dell Alienware 14 Power-Button Board Replacement, Slide the Hard-Drive Cable: step 32, image 1 of 1
      • Slide the secondary hard-drive cable into the system-board connector and press down on the connector latches to secure the cable.
      Ask FixBot
    17. Dell Alienware 14 Power-Button Board Replacement, Align the Screw Holes: step 33, image 1 of 1
      • Align the screw holes on the secondary hard-drive assembly with the screw holes on the computer base.
      Ask FixBot
      • Replace the screws that secure the secondary hard-drive assembly to the computer base.
      Ask FixBot
    1. Dell Alienware 14 Power-Button Board Replacement, Disconnecting the Status-Light Board Cable: step 35, image 1 of 2 Dell Alienware 14 Power-Button Board Replacement, Disconnecting the Status-Light Board Cable: step 35, image 2 of 2
      • Lift the connector latch and pull the pull-tab to disconnect the status-light board cable from the system-board connector and slide the cable into the slot on the computer base.
      Ask FixBot
    2. Dell Alienware 14 Power-Button Board Replacement, Remove the Screws: step 36, image 1 of 1
      • Remove the screws that secure the palm -rest assembly to the computer base.
      Ask FixBot
    3. Dell Alienware 14 Power-Button Board Replacement, Turn the Computer Over: step 37, image 1 of 1
      Ask FixBot
    4. Dell Alienware 14 Power-Button Board Replacement, Pry the Palm-Rest Assembly: step 38, image 1 of 2 Dell Alienware 14 Power-Button Board Replacement, Pry the Palm-Rest Assembly: step 38, image 2 of 2
      • Using a plastic scribe, pry the palm-rest assembly from the computer base.
      Ask FixBot
    5. Dell Alienware 14 Power-Button Board Replacement, Lift the Palm-Rest Assembly: step 39, image 1 of 1
      • Carefully lift the palm-rest assembly and turn it over.
      Ask FixBot
    6. Dell Alienware 14 Power-Button Board Replacement, Release the Connector Latches: step 40, image 1 of 2 Dell Alienware 14 Power-Button Board Replacement, Release the Connector Latches: step 40, image 2 of 2
      • Release the connector latches to disconnect the flexi-cable from the system board.
      Ask FixBot
    7. Ask FixBot
    8. Ask FixBot
      • Connect the flexi-cable to the connector on the system board.
      Ask FixBot
    9. Dell Alienware 14 Power-Button Board Replacement, Turn the Palm-Rest Assembly: step 44, image 1 of 1
      • Turn the NEW palm-rest assembly over and slide the status-light board cable through the slot on the computer base.
      Ask FixBot
      • Align the palm-rest assembly over the computer base and snap the palm-rest assembly into place.
      Ask FixBot
    10. Dell Alienware 14 Power-Button Board Replacement, Close the Display: step 46, image 1 of 1
      Ask FixBot
    11. Dell Alienware 14 Power-Button Board Replacement, Replace the Screws: step 47, image 1 of 1
      • Replace the screws that secure the palm-rest assembly to the computer base.
      Ask FixBot
    12. Dell Alienware 14 Power-Button Board Replacement, Slide the Status-Light Board Cable: step 48, image 1 of 1
      • Slide the status-light board cable into the system-board connector and press on the connector latch to secure the cable.
      Ask FixBot
    1. Dell Alienware 14 Power-Button Board Replacement, Disconnecting the Power-Button Board Cable: step 49, image 1 of 3 Dell Alienware 14 Power-Button Board Replacement, Disconnecting the Power-Button Board Cable: step 49, image 2 of 3 Dell Alienware 14 Power-Button Board Replacement, Disconnecting the Power-Button Board Cable: step 49, image 3 of 3
      • Lift the connector latch and disconnect the power-button board cable from the connector on the status-light board.
      Ask FixBot
    2. Dell Alienware 14 Power-Button Board Replacement, Peeling the Power-Button Board Cable: step 50, image 1 of 2 Dell Alienware 14 Power-Button Board Replacement, Peeling the Power-Button Board Cable: step 50, image 2 of 2
      • Make a note of the power-button board cable routing and peel off the power-button board cable from the keyboard bracket.
      Ask FixBot
    3. Dell Alienware 14 Power-Button Board Replacement, Remove the Screws: step 51, image 1 of 1
      • Remove the screws that secure the power-button board to the palm-rest assembly.
      Ask FixBot
    4. Dell Alienware 14 Power-Button Board Replacement, Lifting the Power-Button Board: step 52, image 1 of 1
      • Lift the power-button board along with its cable off the palm-rest assembly.
      Ask FixBot
    5. Dell Alienware 14 Power-Button Board Replacement, Align the Screw Holes: step 53, image 1 of 1
      • Align the screw holes on the NEW power-button board with the screw holes on the palm-rest assembly.
      Ask FixBot
    6. Dell Alienware 14 Power-Button Board Replacement, Replace the Screws: step 54, image 1 of 1
      • Replace the screws that secure the power-button board to the palm-rest assembly.
      Ask FixBot
    7. Dell Alienware 14 Power-Button Board Replacement, Route the Power-Button Board: step 55, image 1 of 1
      • Route the power-button board cable on the keyboard bracket and adhere the cable to the keyboard bracket.
      Ask FixBot
    8. Dell Alienware 14 Power-Button Board Replacement, Slide the Power-Button Board Cable: step 56, image 1 of 2 Dell Alienware 14 Power-Button Board Replacement, Slide the Power-Button Board Cable: step 56, image 2 of 2
      • Slide the power-button board cable into the status-light board connector and press down on the connector latch to secure the cable.
      Ask FixBot
Terrence15
80,143 Reputation
441 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
45 Members
12,349 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 18
Past 30 Days: 67
All Time: 931
